Hi Jim, There are a few things you can do to improve the lighting, but anything you do will benefit from better current to the lamps. The stock design does not use a headlight relay so all the current from the bulbs is passed through all the (relatively small) wiring to the switch, and then back to the lamps. Installing a coupe relays makes a big difference.
Aside from that you can upgrade the headlight lenses themselves, but that's more a visual update than actually better lighting unless the stock lenses are hazy and yellowed badly. Some have done HID's as well, but that's not my preference.
Nate,l did the head light mod,got through with it to day and it is so much brighter,but the light needs to be adjusted bad,l am going to get new lens and then I will adjust them then.thanks NATE
JIM
Another question,why would they put clear lens on the side lens and than put a Amber bulb in it,believe l am going to put a clear bulb in it,think it will give more side view.
JIM
Technically, I think the side view lamps are supposed to be amber by law. It's a regulation thing, just like how all rear facing lamps are supposed to be red (except for the reverse lights).
Thanks NATE,
I might still put a clear bulb in it and see how it work.
Jim
That won't give you anymore light to see by while driving. Those small side light are marker lights not part of the headlight, and like Nate said are supposed to have amber bulbs in them.
I've been considering experimenting with LED capsules in my truck's headlights but I was waiting for the technology to mature a bit more. I installed a set in my Civic a couple years ago- they're still working fine but the light pattern is less than optimal.
They should put much less demand on the wiring and switch due to their efficiency, just not sure how they will last operating at a lower voltage. Anyone have any experience with them in this application?
I believe reason behind clear lenses for markers & brake lights (Euro style) is because of what exposure to sun can do to colored plastic, turning it brittle. Colored bulbs aren't as susceptible to it.
