Headlights
Old Dec 13, 2017 | 08:39 PM
  #31
2006F350KITT's Avatar
2006F350KITT
Yes definitely I just got a 95 f250 7.3 a month ago and am gonna use it for a work truck I'm a stickler about bright lights at night so I bought some Silver Star ultra bulbs but sounds like I need this harness to really take advantage of the bulbs the bronco grave yard site seems like a good price and I've purchased stuff from them before but it's been a good 10 years as I've been driving super dutys the last 10 year but just added this 95 I
  #32
2006F350KITT
Old Dec 13, 2017 | 08:57 PM
  #33
Hit Man X's Avatar
Hit Man X
Thumbs up
My 6.4 was totaled a few years back, so I understand. I have had my F150 for what seems like forever, needed a truck after Harvey...so that is why I am driving this first gen 7.3 now. It needed a few thousand dumped into it (seven good tires was biggest cost) so be 100% durable. New lenses all around is my next thing to do, luckily they are cheap!
Let me figure out how to attach a picture here and I will post them.
Old Dec 13, 2017 | 09:02 PM
  #34
2006F350KITT
Right on. That would be awesome. Ya I still have my 06 f350 and it's a pretty good truck actually I really like it. But I knew I wanted a early 7.3 with a utility bed or a SD 7.3 for a work truck and found this 95. Bronco grave yard has 10 percent off to December 17 so I think I'll get that harness. My light lens are a little yellowed as well but I have a kit that has a buffing wheel that connects to a drill that I'm gonna use to clear them up I hope. Glad you made it safely from Hurricane Harvey!
Old Dec 13, 2017 | 09:59 PM
  #35
Hit Man X's Avatar
Hit Man X
Thumbs up
My F150 ended up with water past the rubber on the windows... so it will be a PITA to get back on the road. We drained the engine and trans as well as the axle. Water poured out for, no joke, three minutes from the trans before ATF came out.
House received 6' for two weeks. No people nor pets hurt, just material crap that can be replaced.
Lets see if these photos attach.
Old Dec 13, 2017 | 11:25 PM
  #36
mcali2's Avatar
mcali2
I just ordered Some super bright LED setup. Im not sure if it will be better or not. I hope so as they use very little power so I will not have to do the power mod. Then again imadding a 1200w light bar and 4 150w cube lights in the bumper. I will have more light. Light bar might get me into trouble LOL
Old Dec 24, 2017 | 09:22 PM
  #37
2006F350KITT
Thanks for the pictures of your kit installed I got the one from bronco grave yard on sale but I have yet to install it yet
Old Dec 24, 2017 | 10:47 PM
  #38
oldbird1965's Avatar
oldbird1965
I just installed Bronco graveyard kit with their headlights. I haven't tried them yet.
Old Dec 25, 2017 | 11:32 AM
  #39
mcali2's Avatar
mcali2
I put in the e bay LED lights and WOW are they bright. 25.00 for the kit and took 2 min to install.
Old Dec 26, 2017 | 03:29 PM
  #40
DIYMechanic's Avatar
DIYMechanic
Got a link? Or pics?
Old Dec 26, 2017 | 04:30 PM
  #41
2006F350KITT
Didnt. Not want to go this route after reading a lot of the negatives of Chinese knock off stuff also my own not so great experience with LED as headlights what I found works best for me is a good set of silver star ultra bulbs and after reading the flaw with the factory wiring on OBS trucks is why I went the relay wiring harness route
Old Dec 26, 2017 | 05:59 PM
  #42
mcali2's Avatar
mcali2
https://www.ebay.com/itm/9007-HB5-CR...53.m2749.l2649
Old Dec 28, 2017 | 02:36 PM
  #43
DIYMechanic
See, the way these things are advertised just torques me off. 1000 watts? Really? I'm sure they're bright, but wattage isn't a measure of how bright they are, it's a measure of how much energy they consume. If those are actually 1000 watts, they'd burn up every stich of wiring in the circuit because at 12 volts, they'd be drawing 83.33 amps. There's no fuse in the truck big enough to run that kind of load. I'm tempted to try them out, but I'm still curious what they draw in actual watts so I could know whether they're actually any easier on the wiring or not.
Old Dec 28, 2017 | 09:09 PM
  #44
Jarrett Campbell's Avatar
Jarrett Campbell
YES hahahaha Marketing at its best. Pretty similar to the "max wattage" on the subs and amps in Walmart
Old Dec 28, 2017 | 11:37 PM
  #45
mcali2's Avatar
mcali2
low beam. it is 2x what i had in old fogged lenses.
