Hitch receiver and reducer
Old Nov 22, 2017 | 08:39 AM
  #46
jaherbst's Avatar
jaherbst
Originally Posted by donovan
There is NOTHING Ford can do to slow down the up and down sea saw affect from the ball of the trailer hitch to the trailer.
The current trucks have a much higher tow rating then most trailers. But saying Weight distribution bars they are not required is not correct. They very much help any many circumstances.
Jack
Old Nov 22, 2017 | 01:15 PM
  #47
Faceplant409's Avatar
Faceplant409
Originally Posted by MJMETHOW
Not a fan of the reducer set up.Lining up 4 hole with a 65 lb weight disturbing hitch is a pain. Thinking about a tack weld to hold everything in place.
Ditto.
I would either use the 2” or 3”. Never 2.5”.
I thought about tacking the reducers together and possibly enlarging the holes just in the reducers so that when the reducers are slid all the way to the ‘stop’ everything Is lined up.
Also thought about adding a set bolt or something to hold spacers in place.
Sooo many other things in life higher on the list than this tho... lol.
Old Nov 23, 2017 | 06:39 AM
  #48
wrvond's Avatar
wrvond
Some things to keep in mind:
1. If you have the three inch receiver, the 2” reducer does not have a flange on it. The 2” reducer for a 2.5” receiver does have a flange and will not fit deep enough for the pin holes to line up. The 3” to 2.5” reducer does have a flange and lines up just fine.
2. Nowhere does the owners manual specifically state a weight distribution hitch is not required. The hitch is a pivot point. Even if it is rated the same with or without a wdh using a wdh is going to shift weight from the rear axle to the steer axle and to the trailer axle(s). This can dramatically affect how the camper behaves while being pulled.
Old Nov 23, 2017 | 06:45 AM
  #49
jaherbst's Avatar
jaherbst
I totally agree!
Jack
harmanrk
Oct 23, 2017 11:20 AM
ksteve06
Jun 3, 2017 09:55 PM
1L243
All Things Towing
19
Aug 24, 2013 11:07 AM
s2gots
All Things Towing
Mar 11, 2005 08:55 PM
TinyOne
Feb 8, 2005 07:49 AM
