Hitch receiver and reducer
Old Nov 21, 2017 | 08:29 AM
  #31
harmanrk's Avatar
harmanrk
Originally Posted by ~erik~
Anyone have any first hand experience using the receiver reducer adapter with a WDH? Is it quiet, or does it bang around back there?
Once you snap your spring bars up, nothing is moving or rattling. The reducer(s) are lifted up in the rear, and shoved down in the front, rotating around the pin.
Old Nov 21, 2017 | 08:35 AM
  #32
6.2caribou's Avatar
6.2caribou
Bought our F250 to tow a trailer that we have on order. I'll be getting a weight distributing hitch with sway control. Our receiver is the 2½" size, but most all the WDH stingers are only 2". I could use the adapter that came with the truck but thought that after spending all this money for the truck, trailer, and WDH I should spend a bit more and get the 2½" one so things aren't slopping around back there.
But then I got to thinking about how a weight distributing hitch works - by torquing the stinger up in the receiver. So theoretically this should prevent the hitch and adapter from slopping around, right?
I stumbled across this while searching for 2.5" adjustable ball mounts. It's a 2.5" WD hitch with a 2" shank...for using an existing 2" WD head.
https://www.curtmfg.com/part/17128
Old Nov 21, 2017 | 09:16 AM
  #33
Poncho450's Avatar
Poncho450
Originally Posted by clc3251
Where did you find a 2.5" hitch extender? I couldn't find one anywhere.
Etrailer.https://www.etrailer.com/Hitch-Acces...ophy/HR26.html
But I was going from 2.5 to 2 inch for my Weigh Safe ball mount. That item both extended it 6 inches and reduced it. You might need to look around some more if you need a straight 2.5 inch extender.
Depending on the trailer you may or may not have to extend your safety chains.
Old Nov 21, 2017 | 09:49 AM
  #34
HRTKD's Avatar
HRTKD
Eric, I was using a 2" WDH shank in my 3" receiver and it did indeed bang around. There was some slop.
A number of manufacturers make a 2.5" WDH shank. Not many make a 3" shank. I have the Andersen 3" shank WDH. The 2017+ Superduty doesn't need as much weight distribution so the Andersen works really well.
Old Nov 21, 2017 | 09:57 AM
  #35
donovan's Avatar
donovan
Reducers
They pissed me off to point that simple welded my adapter on to my tow bar. Now it work like it should.
  #36
clc3251's Avatar
clc3251
Plenty of reducers available that also extend. I still can't find a straight 2.5" extender. I'm going to just weld one up so that my tailgate clears my trailer jack. I only need about 6".
Old Nov 21, 2017 | 10:10 AM
  #37
Poncho450's Avatar
Poncho450
Sounds like the same reason I needed to extend. I pull Little Giant ladders out of the back of the truck at every job and the part of the tailgate with the camera was dangerously close to hitting the trailer jack every time I opened it.
Old Nov 21, 2017 | 11:04 AM
  #38
~erik~'s Avatar
~erik~
Thanks for the info. I'm going to get a Blue Ox WDH from the trailer dealer, and they'll be installing it and setting it up. They told me a 2½" stinger would be $200 extra so they weren't that far off. I guess I'll start with the stock 2" component, see how much noise I get. If it's bad I'll get the Curt shank.
Old Nov 21, 2017 | 11:34 AM
  #39
HRTKD's Avatar
HRTKD
Why not get the Blue Ox 2 1/2" shank from the start?
https://www.etrailer.com/Weight-Dist...x/BXW2003.html
Old Nov 21, 2017 | 11:40 AM
  #40
BII Plow Truck's Avatar
BII Plow Truck
As far as I know, there are no 3 inch weight distribution hitches on the market yet
WDH is no longer required with these new trucks....a lot of engineering went into the factory receiver hitch which distributes the weight throughout the frame already.
Old Nov 21, 2017 | 12:09 PM
  #41
KMP44's Avatar
KMP44
I use my wdh in the adapter. No banging or movement at all. Actually is better than the old truck with the 2" hitch.
I towed my ~6,000 lb travel trailer without using the bars for the first few trips, as its not required per the manual. I was using the WDH since it was the only one I had with the right height. No complaints about the way it tows but one day I through the bars and friction sway control on just to try it. Not sure how much the bars did, but the sway control made for an even better towing experience. I haven't scaled it yet to see how much the bars are doing, but I liked the improved handling, so I've continued using the wdh.
Not sure how the OP's dually might compare, but after trying both with and without, I would highly recommend considering using a sway control setup.
Old Nov 21, 2017 | 12:12 PM
  #42
donovan's Avatar
donovan
AH Yes and NO
There is NOTHING Ford can do to slow down the up and down sea saw affect from the ball of the trailer hitch to the trailer.
The current trucks have a much higher tow rating then most trailers. But saying Weight distribution bars they are not required is not correct. They very much help any many circumstances.
Old Nov 21, 2017 | 12:51 PM
  #43
harmanrk's Avatar
harmanrk
Required, being the operative word there. Yes, the hitch is rated for a weight carrying rating equal to its weight distributed rating, so in that respect, WD is not 'required'. That said, First time I towed with the new truck, I took my front and rear measurements. Put the trailer on the ball, and remeasured. Front went up an inch, rear when down 2.5. Snapped up the spring bars, and the front was back to the starting height (nearly), and he back was up 1.5 (1 inch of squat). Does that mean that without using them, my headlights were not aimed higher than normal? That steering would not have been lighter than normal? It may not be required, bit that's not to say it does not help make the drive more pleasant.
Old Nov 21, 2017 | 01:58 PM
  #44
~erik~'s Avatar
~erik~
Unfortunately for the size trailer I'm getting the 10,000 lb capacity with 1000 lb hitch weight Blue Ox would be appropriate:
https://www.etrailer.com/Weight-Dist...x/BXW1000.html
and it comes with the 2" shank.
I've got an e-mail in to etrailer to ask if I can the larger stinger on the smaller WDH.
thanks!
Old Nov 22, 2017 | 07:29 AM
  #45
chosenone357's Avatar
chosenone357
Didn't know I was supposed to get 2 sleeves... Salesguy called me within minutes of me contacting my dealership saying he was in the lot looking for the 2.5 -> 2 sleeve on SD's they had and would get one shipped to me if he couldn't find one.
