This is what I use. I like it because I can use the Ford key in my fob and don't have to carry around a separate key. You can search the web for the part number and find it for $19.99.
That Bolt hitch pin looks very interesting, to have it keyed to match the truck. One less key is a good thing. However its hard to tell from the stock photos sometime, but there is one shot of it, that make the lock portion look HUGH. Those of you have have it, how bad it is really? It looks to be much larger than the Master Lock offering.
The Bolt hitch locking portion is fairly large but it doesn't bother me. It also passes stress tests that break other locks. The single key is way more convenient and well worth the extra size. I also like the Bolt better than the all metal locks.
I found a 4”x5/8” hitch pin and drilled out the hole to accept a Master lock.
Same lock I use for all my trailers and job site needs.
1 key does it all.
i second the suggestion on the Bolt hitch pin lock. I've started transitioning all my RV and camping locks to use a Bolt lock that uses the truck key. It's very convenient!
Sorry guys. Ford says that the hitch pin needs to be rated at 21,000 lbs. The ones above that I investigated above only have a 10,000 lb rating.
Perhaps someone can devise a locking mechanism for the groove on the stock hitch pin.
Only needs to be 21K if you are pulling that heavy. My travel trailer is only 7500, so 10K is fine. Not saying I would not like something more, but I can wait until the next travel trailer to upgrade.
I wrote a post/thread about this very subject - i use a combination lock (no key required)
and picked up some pins at Tractor Supply - pictures and hitch pin options here:
