Just wondering if a 305x70rx17 will fit my stock 2016 f250 without any rubbing. If not, does anybody know the largest mt that my truck will accommodate?
That tire will easily fit. You've got room to go larger if you want. A bit wider and taller and you'll still be ok. I'm a fan of the 295's, but you could do a 35/12.5 or 315/70.
I had 315/60/20 Toyo MTs on my 2012 and they rubbed the radius arms. I have a friend with 35x12.50x20 Toyo RTs and they rub the radius arms. My 37x13.50x20 Toyo RTs rub the radius arms.
The radius arms are likely the first spot that will rub as long as you don't go too big on the overall diameter. Rubbing the radius arms doesn't bother me, but it bothers some people.
How many times can you say radius arms in one post?
I got the 315's on my truck and they fit perfectly ! No rubbing, and the ride is great. I went with the Firestone m/t's and I am so pleased. I will post up a pic or two tomorrow maybe.
