Auxiliary Gas Tank Questions
I just bought a '71 F100 long bed with auxiliary gas tank. Never had a truck with two tanks before, and the PO only had it about a year, during which time he didn't drive it much. He knew nothing about them. It has this switch on the driver's side floor, near the sill plate:
I assume that this was added somewhere along the line, right? It still has the switch on the dash. Am I safe in assuming the dash switch is inop? Or does the dash switch only switch over which tank is displayed on the fuel gauge?
Also, the fuel gauge only shows a little over half full when I fill the main tank. Not sure if it's a problem with the sending unit, or if indeed it only gets half a tank on a fill, for some reason. Easiest way to find out, I guess, would be run the tank dry. But before I do that, I need to figure out the auxiliary tank switch so I don't get stranded somewhere without gas! Any help would be appreciated. Thanks!
For what its worth, I use the dash selector. I've never gotten more then 3/4-7/8 full tanks on my '70. There are lots of posts about guys putting blocks of wood under their tires to help with the air gaps when filling. Be aware that a lot of people on here, including myself, can tell you that the main tank will spill out the fill tube on a hot day on an incline with a "full" tank. Whenever I'm filling up and going to put some miles on it, I fill it and make sure I pull from the main tank first.
He knew nothing about them. It has the "manually operated" fuel tank selector valve on the driver's side floor, near the sill plate.
Wrong.
No, because it has nothing to do with switching the tanks.
Wrong.
Manually operated fuel tank selector valve located on the floor adjacent to the drivers side of the seat.
The selector switch, located on the left side of the dash only changes the dash fuel gauge from one tank to the other.
Someone, when they installed the carpeting, covered up the bezel that is below the handle that tells which way to turn the valve.
So, whoever did it...used a grease pencil (probably a laundry marker) to write the instructions on the sill plate.
The fuel sending unit float (C0AZ-9202-B) is made of two pieces of brass soldered together. Solder breaks down, gas seeps in, float slowly settles towards the bottom of the tank.
The float is available from Ford and is the same for ALL 1967/79 FoMoCo vehicles.
1967/72 F100/350 w/optional 25 gallon auxiliary fuel tank: These were only available factory installed, there was no dealer installed accessory kit.
You can order a copy of your trucks original build sheet by passing along your VIN (and some bucks) to martiauto.com
I figured the auxiliary tank was original; I just questioned the switch and hand-lettered instructions. My (incorrect) assumption was that the dash switched was what switched from main to auxiliary, and that someone had added the lever on the floor. I learned something very valuable tonight!
The build sheet was retrieved and saved by a previous owner years ago when he apparently had the seat reupholstered (which is a topic for another thread--WAY too squishy!!!). But it's in pieces and discolored, so hard to make out anything.
1975/79's have a fuel tank selector valve and solenoid assy mounted on the cross member.
The switch located in the heater control panel changes the tanks and the dash fuel gauge from one tank to the other.
jackstar
06-12-2017 04:00 AM
baybbuttrkup302
09-28-2011 07:45 PM
