Sponsored by: Real Truck
Need help on Payload Capacity information
Old Nov 13, 2017 | 03:37 PM
littleapple's Avatar
littleapple
I have a 2015 F250 XLT, Crew Cab, 6.7 V8, 4x4 with 3.55 axle ratio. When I look at any of the online Ford Technical Specifications for my truck, they all say that the payload capacity is 3,150 lbs. But, the "Tire and Loading Information" sticker on the truck says that "combined weight of occupants and cargo should never exceed 2038 lbs." Can anyone help me out so that I can understand why the info is different?
Old Nov 13, 2017 | 04:14 PM
Chuck's First Ford's Avatar
Chuck's First Ford
the "Tag" on the door is the Ford real numbers for YOUR TRUCK... online is a general information.
4x4, Diesel, larger cab are negatives to carry.
my opinion.
Old Nov 14, 2017 | 01:47 PM
wrvond's Avatar
wrvond
Online information is based on data from a "typical" truck and reflects "what could be".
As each truck is rolled off the assembly line, it gets weighed and a "Tire and Loading Information" sticker is generated. This reflects "what really is".
Old Nov 14, 2017 | 02:06 PM
'65Ford's Avatar
'65Ford
Only way to know for sure is to weigh your truck...front and rear axles separately. Subtract the axles weights from the respective axle ratings. Also subtract the truck's total weight from the gross vehicle weight rating. If you adhere to the truck's gross vehicle weight rating, you'll likely come up with a disappointingly low payload capacity.
You'll also find that adhering to the truck's gross vehicle weight rating leaves you with an abysmally low fifth wheel or goose neck tow capacity. Say you only have 2038 lbs of payload capacity. Add 4 average passengers and a hitch. That leaves you with enough payload to tow about 6500 lbs of fifth wheel or goose neck trailer...kind of silly considering the drive train you have.
Paratrooper84
6.7L Power Stroke Diesel
47
Aug 14, 2012 08:39 AM
faeck
All Things Towing
Mar 11, 2009 08:14 PM
Jim McCarty
Oct 16, 2006 11:09 PM
zelnar
All Things Towing
Mar 1, 2002 09:10 PM
docolena
All Things Towing
Jun 13, 2001 03:47 PM
