Overdrives
Old Nov 8, 2017 | 08:11 AM
garypettengill's Avatar
garypettengill
Overdrives
I'm looking for input. Is anyone running a Gearvendors everdrive behind a C-6 in a shortbed 4x4? I'm concerned about the steep drive shaft angle and it's surviveability. I'm running a stock suspension on my '77. Any input would be helpfful.
Old Nov 8, 2017 | 08:54 AM
willowbilly3's Avatar
willowbilly3
You could maybe get a custom rear driveshaft made with the ball and trunnion (Rezeppa) type joint like FWD applications use. They will transfer power to almost 45 degrees and the old cross type ujoints can only efficiently transfer through about a 15 degree angle.
Old Nov 8, 2017 | 10:33 PM
boingk's Avatar
boingk
Could always swap to a T-18 or NP435 and gain a crawler gear, plus have the benefit of a much shorter but still robust transmission.
- boingk
Old Nov 9, 2017 | 08:33 AM
garypettengill
- boingk
Not looking for a crawler gear, looking for better cruising rpm's. 3000 rpms at 65 mph is just crazy with a 400 c.i. engine.
Old Nov 9, 2017 | 06:17 PM
boingk's Avatar
boingk
Fair enough.
If you're pulling 3000rpm at 65mph then why not just change to higher diff gears? 3.54 ratio would see about 2500rpm and higher than that would be better still.
I'm going to 3.54's from 4.56's, at the moment the 4.56's deliver a good 'relaxed' cruising speed of about 45mph hahaha.
- boingk
F-250 WARHORSE
Aug 1, 2013 12:37 AM
TFagerholm
Oct 20, 2011 10:27 PM
Fordman18
Sep 8, 2010 05:48 PM
77custom408
Nov 18, 2008 11:00 PM
redteamgo2000
Oct 28, 2008 10:53 PM
