u-joint problem at transfer case
Old Oct 17, 2011 | 10:51 PM
TFagerholm's Avatar
TFagerholm
Hey all,
I'm looking for a little help here. I have a 78 F250, 400m, w/ 6in lift that keeps blowing the u joint on the rear drive shaft right by the t case. The t case is married, pretty sure its a NP205, and there is no double cardan joint on the rear drive shaft and I am wondering if the driveshaft angle is too great at the t case. I've blown 3 u-joints in about 8 months. Granted they were cheap u-joints but that still seems premature. Heavy duty one goes in next.
Someone suggested I lower the t case 1/2" or so to lessen the angle on the joint but I'm not sure how to do that since the mount on the t case is not very far from the transmission mount.
Any help is greatly appreciated.
Thanks!
Old Oct 17, 2011 | 10:56 PM
78_f150's Avatar
78_f150
Originally Posted by TFagerholm
Hey all,
Thanks!
are you going offroad, driving hard ect. that will kill U joints. plus the stock u joints are pretty wimpy units. ive only dropped 1 U joint and im using a 1330 at the t-case and a 1350 at the axle.
check the angle, you should be able to see it visually if the angle is to steep.
Old Oct 18, 2011 | 12:26 PM
NW 150's Avatar
NW 150
you can also try axle shims for the rear, that barely add lift, and angle it more towards the t-case. There should be a few different degrees to choose from.
Old Oct 18, 2011 | 03:50 PM
TFagerholm's Avatar
TFagerholm
The angle at the pumpkin is good, barely anything visable. The one at the transfer case is more severe. Would a double cardan help? Or do I drop the T case a bit. There looks like a spacer in there that could be removed. I'll post pics soon.
I use it mainly for cruising around, hauling lumber, and occasional off road use. More if i knew anyone in may area to off road with...
Thanks for the help.
Old Oct 19, 2011 | 10:00 AM
TFagerholm's Avatar
TFagerholm
So for whatever reason I can't attach images but they are in my gallery. Hopefully anyone can look.
Thanks
Old Oct 19, 2011 | 10:44 AM
ctubutis's Avatar
ctubutis
Only paying supporters can directly attach files to posts, the rest of us need to put images up on a hosting site (can be FTE galleries or albums) and source 'em from there.
Place the URL of your image between two [ img ] tags to have 'em show up inline.
User Gallery & Picture Display Help - Ford Truck Enthusiasts Forums
Old Oct 20, 2011 | 09:31 PM
TFagerholm's Avatar
TFagerholm
Images
Album at
77 f250 pictures by TFagerholm - Photobucket
Old Oct 20, 2011 | 09:34 PM
TFagerholm's Avatar
TFagerholm
Old Oct 20, 2011 | 10:21 PM
thekingofcows's Avatar
thekingofcows
I think you should invest in a forged ujoint like a spicer, these are much stronger.
Old Oct 20, 2011 | 10:27 PM
thekingofcows
For the most vibration free setup, find a driveshaft off of a superduty many of these came with a forged 1350 cv and 1350 ujoint in the axle end, this would require a custom flange though, and most Likely some shortening which entailes a lathe and other less common shop tools. I run this setup on my camo job and it has not failed me 'yet' at roughly 12 inches over stock and sizeable meats.
Farmboy429
Offroad & 4x4
Jun 12, 2014 07:18 AM
scroller bill
1978 - 1996 Big Bronco
Oct 21, 2006 10:19 PM
smallblock351w
Apr 26, 2006 10:02 PM
GeneStoner
Mar 17, 2005 10:53 AM
msmyth
Sep 3, 1999 07:20 PM
