Front CV joint
Old Sep 7, 2010 | 06:56 PM
Fordman18's Avatar
Fordman18
Front CV joint
I have a 1978 f150 with a 400, 4-speed, np205 transfer case, and a high pinion Dana 44. My front driveshaft doesn't have a CV joint on it and my transfer case front output doesn't have a CV joint style yoke on it. Is this common or is it something the previous owner did? I don't have any binding issues but I'm about to install a 4 inch suspension lift. Thanks for the help.
Old Sep 7, 2010 | 07:18 PM
southernboy0122's Avatar
southernboy0122
Are you talking about u joints? im pretty sure cv joints are the axles on front wheel drive cars, or ifs 4x4s.
Old Sep 7, 2010 | 07:27 PM
Fordman18's Avatar
Fordman18
Sorry, I must not know the name. It's like a knuckle about 4 inches long or so. Cardan joint? Does that sound right?
Old Sep 7, 2010 | 07:39 PM
tabascom16's Avatar
tabascom16
It is called a Double Cardan joint. They work better than a single ujoint for constant rotational velocity. IT seems like some trucks have them and some don't but then again it is hard to say if things were aftermarket. When I got my 79 F250 with a C6 and 44 front it had a double Cardan joint on it. I picked up a parts truck that seemed bone stock with a T18 and D60 front and even though the driveshaft was quite a bit shorter it only had a single universal joint. If it doesnt have one I wouldnt sweat it. I wonder how much one would smooth the ride out in 4wd at speed?
Old Sep 7, 2010 | 07:50 PM
Fordman18's Avatar
Fordman18
Ok, cool. I guess I'll scratch that off the to do list then.
Old Sep 7, 2010 | 10:36 PM
c.l.nye's Avatar
c.l.nye
it smooths it out quite a bit,I put one on mine years ago when I was plowing snow and ran with hubs locked 6mos out of the year.
Old Sep 8, 2010 | 08:02 AM
704 dentside man's Avatar
704 dentside man
I call the cardan unit a cv joint as well...even the dshaft shop I just brought a couple shafts to called them cv joints...so it's an interchangeable term IMO. Regardless, the CV joint makes for a waaaaay smoother rotation, and alot easier to just throw in and not have to worry about any vibrations. However, you're looking at about $110 per CV to be rebuilt, as opposed to a $10 U-Joint.
Old Sep 8, 2010 | 08:25 AM
Joseph69's Avatar
Joseph69
Its all about the angles, if there is a CV then the other joint needs 0% of pinion angle. If there is no CV then the pinion angles of each end need to match, thus canceling each other out ( the whole drive shaft works as a CV)
Old Sep 8, 2010 | 08:43 AM
Blown 331's Avatar
Blown 331
My truck doesn't have the double carden/CV on the front shaft either. I never noticed any vibrations or anything like that. Never noticed anything when driving for 40 miles in the snow or when driving home in Fwd with the driveshaft thrown out. lol.
My dads 1979 F-250 full time DOES have the double carden/CV so maybe the full time has something to do with it. Does anyone know what criteria determine if the truck got one or not? My dad thought I was better off not having one because he said keeping the center greased was a pain. I haven't seen a reason for ME to have one so I'm happy with out it.
Old Sep 8, 2010 | 09:09 AM
704 dentside man
I can't seem to find a rhyme or reason as to what got them and why. I've had trucks and Broncos with 205's that have the front CV joint and I've had them without...same with 203 equipped rigs. But who knows what coulda been done in the last 30 years. I really don't think greasing the center is that big of a deal at all...a ton easier than greasing wheel bearings. As for you being happy with the Ujoint style...I have been too, and I really don't see a point to swapping for one style or the other, even though I prefer the CV...they just seem to last longer to me and they also seem to 'enhance' smoothness, if that makes sense.
Old Sep 8, 2010 | 05:48 PM
gus11208's Avatar
gus11208
I wonder if the 78-79 f-250 were the only trucks to have the cv joint up by the tcase i have 2 78 f250 and had 1 79 f250 and all 3 had the cv joints by the tcase.
Jmeyer1990
1997 - 2003 F150
13
Apr 17, 2015 08:31 AM
9thPony
Jan 17, 2014 12:47 AM
stevebigos
Nov 17, 2013 09:17 AM
MBBFord
Offroad & 4x4
15
Aug 21, 2007 09:10 PM
aerocolorado
Aerostar
15
Nov 22, 2004 01:24 PM
