1990 e350 grille
Old Dec 4, 2017 | 08:08 PM
6door74's Avatar
6door74
nice work, it looks good. i plan to get a grille for my 2006
Old Dec 5, 2017 | 04:07 PM
joey7478's Avatar
joey7478
Originally Posted by 71Choptop
Well it's done, I am happy. Only downside, although not for me because I ran into the same thing w/my '93 when I installed a billet grille was that you can no longer stick your hand in to unlatch the hood, I carry a 1' piece of wood lathe and stick it in between the 2 top horizontal rows...
look great! Hows it bolt on Thanks joey!
Old Dec 9, 2017 | 01:35 PM
71Choptop's Avatar
71Choptop
Remove grille, remove center section w/squares, do not trim to close on the left and right sides, remove all brackets from new grille, it will just fit top and bottom, you need to cut out little sections of the back side top and bottom, old grille surround, for it to lay completely in, tapered a little on the bottom 3 or 4 , as that is how the '90 f150 is build, bond it in or use screws to hold it in place. have other pics.
Phillyrube
Dec 4, 2012 06:11 AM
bradplock
Appearance & Dress-Up
Jul 23, 2006 09:10 PM
WhëëlMå1
May 31, 2005 12:48 PM
4.2Lbeast
Feb 12, 2005 07:17 PM
JAAMina
1997 - 2003 F150
Aug 4, 2003 01:16 AM
