Ford OEM thermostat sticking
I replaced the OEM Ford thermostat 2 years ago because it was sticking. I put on 30k since replacing.
It's sticking again. Somedays the ECT will not go above 183 degrees. This morning it was running normal again at 192 degrees.
Time to replace. I will either replace with another Ford OEM or the Mishimoto high temperature thermostat.
I drive the 6.0 van.
Any thoughts on the Mishimoto high temperature thermostat? Amazon sells it for $50.
In over 14 years I’ve never had a Motorcraft T/S issue in the 6.0. In the Ranger I found them to be more reliable. In the LS I had a replacement from 4 years ago go bad after an overheat (not its fault) and it’s replacement is fine.
Not that I don’t think others have had issues, but it’s just not my experience.
