Thermostat?
Ensure you use the right one if you are replacing the TSTAT
CAUTION:
The specified/required thermostat does not contain an internal bypass, since the bypass is located in the cylinder block. Whenever the thermostat is replaced, it is mandatory that only Motorcraft E5TZ-8575-C or Navistar 1807974C94 thermostat be installed.
CAUTION:
I had one stik open comming home from elk camp, colder than snot, at night (but of course) spitting snow, and I was about sh>>ing gold twinkies, though the eng. was going out. (for some reason I allways asume the worst)...O thi was in my 77 4X4..
Not really. 195F is the ideal temperature for fuel economy, engine wear and oil performance. But it won't kill it to run another few days on the cool side. Your MPGs will likely be affected, so that is reason enough to change it as soon as you can.
