Experience using Rislone Head Gasket Fix
Old Oct 22, 2017 | 10:36 PM
mark6x43's Avatar
mark6x43
I know it's not really the ideal fix, but I was wondering if anyone has had any experience/luck using Rislone or Bar's Leak Head Gasket Fix to repair leaking head gaskets or EGR coolers? My truck is an 05 F350 6.0 diesel and I've been loosing coolant out of the overflow tank cap. It also will blow a little white smoke out the exhaust on a cold start but cleans up in a few seconds.
Old Oct 22, 2017 | 10:46 PM
joe blow's Avatar
joe blow
I will put it to you this way. If you want to cause more damage to your engine, radiator, oil cooler and wallet then pour that $h*t in your engine.
The ONLY fix is doing it the right way. First properly diagnose your problem as some have misdiagnosed head gaskets and it was a bad cap etc....just my opinion
Old Oct 22, 2017 | 11:45 PM
diesel_dan's Avatar
diesel_dan
Deleted, I can't post what I'm really thinking...
Old Oct 22, 2017 | 11:48 PM
04badford's Avatar
04badford
Any gauges ? Could be a few things , blown EGR cooler, head gaskets or oil cooler plugged , bars leak or the like will plug things up like mentioned , you don't need multiple issues , need to look at oil/ coolant temp spread, white misty sweet smell is coolant , park the truck nose down slope for 4 to 8 hours then pull the EGR valve , what you don't want to see is wet coolant or sitting coolant down there, we need your temp spread and where your coolant level sits , also is it pukeing out the degus bottle?
Edit do you have the old style degus cap or new?
Old Oct 23, 2017 | 03:51 AM
Yahiko's Avatar
Yahiko
Oh My God, I hope that you didn't use it.
Old Oct 23, 2017 | 06:04 AM
darrellbarnes's Avatar
darrellbarnes
What they're trying to say is it will plug your oil cooler and in reality, it's highly unlikely to actually work on your head gaskets either.
Old Oct 23, 2017 | 07:48 AM
DSMMH's Avatar
DSMMH
If you don’t have coolant coming out the tail pipe or oil in the coolant or coolant in the oil, I would suggest you look into Titan Head Gasket sealer. It is significantly different then the others. Read the reviews. It is also pricy.
Ed
Old Oct 23, 2017 | 07:54 AM
bismic's Avatar
bismic
Ed
Ed - Have you used this on your 6.0L or do you know anyone that has?
Old Oct 23, 2017 | 08:36 AM
DSMMH's Avatar
DSMMH
Yes I did with good results. Like I said it is pricy and time consuming. Directions must be followed. The only con was my EOT temp went up 10*. That does not concern me since I use RP synthetic oil. I’m sure the sealer coated the cooler, reducing it’s efficiency. Also, my EGT temps came down during normal driving and during acceleration. I use to have a coolant filter with a pressure gauge. Before I used Titan, I would always have pressure in my cooling system when left overnight. Now I have zero pressure when I squeeze the upper radiator hoses.
Mark, I’ll get the “I’m an idiot” replies for doing this. Like my using a K&N reusable oil filter or using RP synthetic ATF which I now have 80k miles on with zero transmission problems.
Ed
Old Oct 23, 2017 | 10:20 AM
joe blow's Avatar
joe blow
That is good it worked for you....No chance in hell I would attempt it since I am sure it would backfire on me
Old Oct 23, 2017 | 10:59 AM
bismic's Avatar
bismic
Also glad you have had success Ed. It can be helpful when people try different things, even the controversial ones. Would love to see updates on your experience every year or so, because with something like that, success is measured in years and many thousand miles.
That said, like Joe, I still don't think I would try it. Seems like too many unknowns and variables for my peace of mind.
Also, the oil cooler performance is something to watch. It isn't just about the outlet oil temp. With heat exchangers like our oil cooler (stacked plate type), the stresses imposed by temperature differentials also come into play. Hotter oil will mean some higher stresses (although 10 degrees isn't much). Remember, your oil temp reading is the cooled temperature and the highest oil temps are far greater than the EOT reading. However, even if you had to replace the oil cooler as the only issue, it would still be quite a success for you.
Old Oct 23, 2017 | 11:41 AM
TooManyToys.'s Avatar
TooManyToys.
To me this is making a $4,000-6,000 dollar repair into a $12,000-16,000 lottery game.
Nylyon's oil cooler I cut apart (silicate sludge), replace with stop-leak.
Sealers may be OK in a commuter gas motor when combustion pressures range from 500-1000psi, but diesels tend to run 2,000-2,500psi range. When gaskets start to leak it's higher damn to generate with a sealer, and with the oil to coolant heat exchanger with small passages, IMO it's a gamble I'm not willing to take.
Old Oct 23, 2017 | 01:27 PM
joe blow's Avatar
joe blow
I have to admit for a second (or a few minutes) I slightly entertained it when mine let loose a few months ago. My left head was physically seeping at the head gasket.....figured I am gonna call pops since he's newly retired from the repair game and I got out of it 15 yrs ago. I figured maybe they have developed some new stuff that will get me by, until I can tackle the monster job.
Well, let us just say that my dad about disowned me for even mentioning it
Then I slapped myself for even considering it.
Joe
Old Oct 23, 2017 | 04:44 PM
wedge542's Avatar
wedge542
My luck it would stop up everything inc the heater core and radiator then just for fun get the trans somehow.
Old Oct 23, 2017 | 09:48 PM
04badford's Avatar
04badford
Maybe on A 7.3 but using bars leak on a 6.0 neh, to the poster , just trying to help ya out , in the long run your going to plug up the oil cooler , just like adding anything like Alcohol or water to the Injectors it's a bad idea ,we can problem solve this with a gauge , did you get a chance to get numbers or park it down hill and pull the EGR valve?
Also running hot or blowing coolant via heads or EGR cooler will Hydrolock the engine, please don't Hydrolock and try to start the engine .
