Valley Pan Drain Plug
Old Oct 20, 2017 | 11:36 PM
Iowa-Rob's Avatar
Iowa-Rob
Hi Guys,
The valley pan drain plug is giving me problems.
Mine rounded out slightly removing it. Also it has a hole thru it and I don't think that its supposed to?
I'm struggling to find a new one. Ford Dealer said that Ford has discontinued making it?
Does anyone know where I can buy it? Did they really discontinue it or did they replace it with a different part number cause they upgraded the part?
Thanks for your help!
Old Oct 20, 2017 | 11:43 PM
Macrobb's Avatar
Macrobb
It's supposed to have the hole through it, yes. That's a drain hole for water, oil etc. that gets trapped in the valley pan - make sure that hole, and the passage under it is clear.
Old Oct 21, 2017 | 02:11 AM
genscripter's Avatar
genscripter
You might want to call R&D IDI Performance. They might have a stock pile of valley pan plugs that you can buy. R&D IDI Performance - Home
Old Oct 22, 2017 | 02:56 PM
Iowa-Rob's Avatar
Iowa-Rob
That’s a great idea. The reason we are working on the engine is because we are installing a new turbo and turbo kit from them.
Thanks guys!
Old Oct 28, 2017 | 08:26 AM
Iowa-Rob's Avatar
Iowa-Rob
So R&D doesn't have any either.
Anybody else have any luck getting a new one?
I believe this is the Motorcraft number that has been discontinued - E3TZ9A450A.
Old Nov 5, 2017 | 09:10 PM
Iowa-Rob's Avatar
Iowa-Rob
Thanks guys!
Anyone know where I can order a Valley Drain plug?
Or a part number??? Maybe IH part #?
Old Nov 5, 2017 | 10:24 PM
Macrobb's Avatar
Macrobb
*sigh*.
If nobody else comes forward, I'm sure I have a couple somewhere.
I'll set myself an alarm to look in my bolts drawer tomorrow.
Old Nov 7, 2017 | 08:29 PM
Iowa-Rob's Avatar
Iowa-Rob
Anyone have any ideas?
How about an IH part number?
MacRobb - any luck?
Old Nov 8, 2017 | 09:22 AM
Aj Cook's Avatar
Aj Cook
MacRobb - any luck?
i know you want one but is it really that important to have in. Doesn’t a bigger drain hole just drain a lot faster or does it help hold down the pan as well?
Old Nov 8, 2017 | 09:10 PM
Macrobb's Avatar
Macrobb
MacRobb - any luck?
I found one. It's used, dirty, but not stripped or anything.
PM me if you are interested.
Yeah, it holds down the pan as well, and I'm pretty sure that you'd get leakage around the valley pan hole without it, into the oil. Not good.
Clint Herrin
Jul 9, 2019 03:55 PM
NYSE
Apr 9, 2019 10:24 PM
2fifty
May 28, 2018 11:58 PM
lucky no. 7
Apr 10, 2012 11:06 PM
thbowen
Apr 24, 2009 06:02 PM
