Bad IP?
Old Nov 8, 2017 | 07:39 PM
FarmallM4's Avatar
FarmallM4
Bad IP?
86 6.9 n/a auto, so I've had my 86 for about two years now and I've done new fuel tank ,fuel line, fuel filters been changed early this year, return lines and return Ts, new injectors so I thought I had a pretty tight fuel system but now I've got this problem it starts hard takes a good while , once started it sounds ok but rpms bounce a little bit when cold but once I'm out on the road it really gains power and takes off then really looses power to the point you almost think it stalled then it winds back up and you take off but even when it winds back up I dosnt have the power that it did have I also notice it smokes , this cycle eventualy lighens up some but power still doesn't get steady nomader how long it runs, when you come to a stop sign it almost stalls out and today it acculay did stall on me , reading around it seems it may be injection pump but I'd like some more expericed opinons , anything thoughts will be appreciated Thank you.
Old Nov 8, 2017 | 10:39 PM
Macrobb's Avatar
Macrobb
Sounds like air in the fuel. Change the lift pump first(it's only a $30 part), and double-check *all* of your fuel lines from the tank forward.
Old Nov 9, 2017 | 07:50 AM
FarmallM4's Avatar
FarmallM4
Ok thanks
Ryan&Barb
Oct 28, 2017 12:19 PM
jrox1596
29
Jan 8, 2015 06:32 PM
blazinjames
Sep 15, 2012 01:33 AM
bigb9582
15
Aug 25, 2009 10:54 PM
SpiritTrakker
Jan 27, 2007 06:34 PM
