1978 - 1996 Big Bronco
ignition
Old Sep 16, 2003 | 08:49 PM
bajabronco's Avatar
bajabronco
ignition
thats what ill do tomorrow, thanks dw
Old Sep 18, 2003 | 10:23 PM
bajabronco's Avatar
bajabronco
ignition
so i fixed it, i ran a new wire from the ignition switch to the solenoid and it worked fine so that wire shorted out somewhere, but just today i took awhile to start and when it was about to and i let back on the ignition it would die, so i thaught the switch was off alighnment, it almost like the circuit is getting cut off before it can complete, do you think the switch is bad, i tried adjusting it every way,
Old Sep 18, 2003 | 10:41 PM
DW2455's Avatar
DW2455
ignition
that sounds like and ignition modual problem, you Ignition modual has two circuts. One fires the coil only while your actually cranking the motor, soon as the engine fire the secondary circut takes over and it continus to run when you release the key, so if your cranking the motor and its trying to start and run but dies when you release the key then there is a problem in the electrical circut or with the ignition modual itself. DW
TreesnFords
Large Truck
15
Mar 31, 2026 04:58 PM
roosplash
Electrical Systems/Wiring
27
Apr 19, 2020 07:44 AM
lasthighboy
Jul 24, 2014 05:54 AM
86halfdozen
Jul 5, 2013 11:47 AM
Bandit91
Mar 12, 2012 11:36 AM
