Automatic Shifting Problems After Neutral Switch Replacement
Old Oct 18, 2017 | 10:16 AM
  #31
1989FordF250's Avatar
1989FordF250
The cable goes into a solid rod at the end of the casing where it goes into the boot. The kickdown lever is spring loaded and should return to its normal position on its own so that's why its going back on its own. I am pretty sure this is a C6 transmission. A way to check if the modulator valve is bad is to remove it and see if there is ATF inside the modulator. Some might come out of the trans but none should be in the modulator.
Old Oct 18, 2017 | 03:10 PM
  #32
whoamonga's Avatar
whoamonga
I did exactly that. I turned the bolt all the way back (towards tailgate) and no change, and tried w the bolt forward (towards engine) and no change but when I went to look at it again, the bolt was turned towards the rear again. Whoch was kinda weird, but I figured it was setting inself to standard position.
Any possibility of the torque converter? The transmission shop is asking $1500~2200 to investigate and repair.
Many thanks, guys!
SeaBassHWD
Aug 9, 2019 06:00 AM
NewXer
Jun 20, 2015 04:39 PM
oct7brian
Jan 13, 2015 05:04 PM
pit_of_pity
Sep 16, 2010 08:36 AM
TLCoates
1997 - 2003 F150
Aug 8, 2004 12:34 PM
