Hole ID please
Old Oct 17, 2017 | 01:12 PM
nikmish's Avatar
nikmish
Question Hole ID please
Hi there,
Could some one please remind me what those holes (1,2,3) for?
Also, what that thing #4 and what it's for?
Picture:
Thank you!
Old Oct 17, 2017 | 02:40 PM
Rembrant's Avatar
Rembrant
My truck, which is a non-AC '84, does not have hole #2 in your picture. Hole #1 I assume is for one of the studs in the plastic heater core housing. I can't see it on mine...I assume because my heater box is in place. The larger one...hole #3, on my truck is where the wiring harness passes through, and goes to the blower fan, solenoid, RH fender, etc.
Not much help, I know...
Old Oct 17, 2017 | 02:55 PM
FuzzFace2's Avatar
FuzzFace2
A little farther back would help on the picture as I cant tell is this AC or non-AC firewall?
And yes they are different!
As a guess it is AC
1- no clue as I don't have that hole on mine.
2- is where the AC wire harness passes thru. (gr/p & bl/y wires)
3- is where the right side main wiring harness passes thru (ALT/REG, head/parking/side maker light, starter SOL wires)
4- a guess and I need to check mine AC drain?
non-AC firewall is different
and yes that is the same cab I swapped firewalls to get AC
Dave ----
Old Oct 17, 2017 | 03:10 PM
nikmish's Avatar
nikmish
Yes, mine is factory A/C.
Thank you very much everyone!
Old Oct 17, 2017 | 04:47 PM
FuzzFace2's Avatar
FuzzFace2
(hi jack)
I have a request being your truck is AC.
It looks like you might have the dash pulled apart mostly looking in the HVAC/Radio area.
I have some wires that are part of the AC harness that have been cut
The 2 wires at the top with plugs should be brown/orange (br/o)
Cut wires are 3 brown/white (br/w) and the other is green/purple (gr/p)
I need to know where the cut wires go to? I am thinking they may go to the fan switch in the HVAC control panel.
If so is there another gray plug that looks like it may go to the fan switch just hanging out back there?
Thanks for any help you can give
Dave ----
(/hi jack
Old Oct 18, 2017 | 12:47 PM
nikmish's Avatar
nikmish
I'll try to look for it this weekend. The wiring is off the dash and in a box though...
Old Oct 18, 2017 | 03:41 PM
FuzzFace2's Avatar
FuzzFace2
Like this one was just before the picture
This is the main harness and you undo that plug/loop and plug in the AC harness.
Fond this out when I pulled this harness out of the box to check this out.
When ever you can I have other things to keep me busy.
Thanks
Dave ----
edit: I take it you are using most if not all of the CV wiring harness being everything under the cab/bed is CV.
Ruckin69
Sep 25, 2018 12:16 PM
TheKirbyMan
20
Jan 19, 2013 07:04 PM
esauls09
Jun 22, 2010 10:26 PM
bucks77ford
Dec 11, 2007 04:41 PM
rboeding
Oct 1, 2006 08:28 PM
