Mirror lens
Old Oct 8, 2017 | 08:17 PM
Tomc750's Avatar
Tomc750
Mirror lens
While backing into my shop I got the RH mirror too close to the jamb, resulting in a cracked lens. Does the lens snap off, or is removal by some other method?
Old Oct 10, 2017 | 07:48 PM
Tomc750's Avatar
Tomc750
Must be I was the only guy with a '17 who was a bit on the tired side while backing in to the garage...
Old Oct 10, 2017 | 08:24 PM
ShotgunZ71's Avatar
ShotgunZ71
Someone should be able to help up here. Lots of helpful members. The thread probably got buried. I dont have any idea myself, other than the glass itself can be ordered at most auto parts stores. Should just pop off the mount behind it.
Old Oct 10, 2017 | 09:11 PM
mhoefer's Avatar
mhoefer
A good glass shop will help you out. If you turn the mirror as far out on the outside edge you will see the plate it's attached to somehow. Tow sided tape or glued to the back plate that adjusts it?
Old Oct 10, 2017 | 09:53 PM
BlackOps450's Avatar
BlackOps450
sorry. Don’t know the answer either. I am ordering the Recon smoked lenses for mine and hope it will have instructions for take off of oem, if no one knows by then.
Old Oct 11, 2017 | 07:40 AM
shortride's Avatar
shortride
The mirror glass is replaceable. 2017 FORD F-250 SUPER DUTY Passenger Side Mirror Glass - 4570H
Old Oct 11, 2017 | 10:53 AM
BLUENGRAY05FX4's Avatar
BLUENGRAY05FX4
While I haven't looked at how my '17 Superduty mirror glass mounts, I would think it is similar to my 2005 F150 that The mirror glass broke...
Inside the mirror there was a plastic "puck" that the mirror glass snapped onto...
Old Oct 12, 2017 | 07:08 PM
Tomc750's Avatar
Tomc750
I did not break the mirror, but rather the light lens on the outboard side. Thanks so far!
Old Oct 12, 2017 | 08:43 PM
Anibal Medina's Avatar
Anibal Medina
Mirror clear turn signal
Get in behind both sides of the lower glass with your fingers and gently pull the glass out. Tilt the upper glass up and to the right for the LH side or up and to the left for the RH side. You will see an opening to insert a small flathead screwdriver. Gently pry out the glass. Five 7 or 8mm bolts to remove once the glass is out. Then the two halves of the mirror will separate.
FL34-13B382-CA Left hand side mirror
FL34-13B381-CA Right hand side mirror
1'stonraceday
19
May 12, 2014 12:04 PM
bakerbuilttracks
13
Dec 7, 2012 05:13 PM
ronjeremy6
Nov 4, 2009 08:30 PM
Dan Taylor
May 5, 2009 03:10 PM
zzf350
Nov 25, 2005 06:52 PM
