Broken side mirror glass. . .
Old May 9, 2014 | 11:43 AM
1'stonraceday's Avatar
1'stonraceday
2001 F-350
Is it possible to replace just the glass mirror on these housings? Rather than the whole assembly? I see them listed at parts stores on line.
If so . . . guide me!
Old May 9, 2014 | 03:06 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Originally Posted by 1'stonraceday
2001 F-350
My driver side mirror got smacked off by a rental RV headed the other way. Which is pretty lucky. Got a new flat mirror cut and installed at a glass shop in Moab for $40. RTV onto the mirror head and go. Later I got a new assembly since I missed the convex part.
Old May 9, 2014 | 04:05 PM
guitarpicr's Avatar
guitarpicr
I think ford sells just the mirror insert. Be ready with some cash though. They arent cheap- Not sure about the internet replacements. What side are you after - pass. or driver ? Large upper glass or small lower ? Sometimes folks on here have a spare one sitting in the garage.
Old May 9, 2014 | 04:46 PM
greg_8507's Avatar
greg_8507
The mirror can be cut if you know how to do it. But after it's cut you will also have to sand down the edges with emry cloth to round out and smooth the edges.
Old May 9, 2014 | 05:57 PM
Pikachu's Avatar
Pikachu
The glass can be replaced on it's own. Rock Auto has it for about $31 per side manual adjust or $81 per side power, both non-heated.
Remove the outer shell by pressing the 4 tabs holding it, which are behind the glass. You can get to them by moving the glass all the way to one side or the other. Do them one at a time while prying on the shell with a plastic putty knife or something else non-marring. Remove the nut on the center pivot, and the glass will pull off. If you decide to go this route and need pictures, I can probably take some tomorrow and post them.
Old May 9, 2014 | 06:35 PM
1'stonraceday
Thanks all! It's the passenger side. They were $80 some dollars on line. But that's less than $250-300 for the whole thing!
Old May 9, 2014 | 08:07 PM
F350-6's Avatar
F350-6
I've replaced the driver passenger side on mine when the mirror got smacked and broke the glass. Plastic housing was still fine. The broken glass made it easy to remove since it was gone anyway.
Seems like the replacement glass came with instructions about using a heat gun or hair dryer to heat up the housing before snapping the new glass into place. Pretty easy process overall.
Old May 9, 2014 | 09:29 PM
JOHN2001's Avatar
JOHN2001
I have a spare on my other two replacement doors. I know one mirror is broken, not sure which side but I'll look tomorrow and if it's the passenger door mirror that's good it's yours if you want it. What style mirrors do you have?
Old May 9, 2014 | 09:39 PM
carltonwebb's Avatar
carltonwebb
tow or paddle style mirror?
Old May 9, 2014 | 09:56 PM
1'stonraceday
It's the tow, no heater or turn signal, and motor driven. (remote control)
I'm assuming "tow" means it pulls out, right?
Old May 9, 2014 | 10:26 PM
carltonwebb
That right..I had a good set of paddle style I took off a truck to install the tow kind.
Old May 10, 2014 | 07:44 AM
JOHN2001's Avatar
JOHN2001
Yep mines a paddle style too... Owell we tried
Old May 10, 2014 | 09:10 AM
jasonc76's Avatar
jasonc76
I have a set of perfectly good tow mirrors off my 99 sitting in my garage if someone needs them. They are telescoping /folding, power adjustment mirrors. No heat. No signal /parking lights. I upgrades to the 2008 style.
Old May 10, 2014 | 09:38 AM
th67ss's Avatar
th67ss
Just replaced my pass side. The new mirror from Ford comes with instructions, the center of the mirror is held on by two ***** type cups. I used a heat gun to warm up the plastic like the instruction said and it popped on easy.
Old May 10, 2014 | 05:55 PM
1'stonraceday
Pikachu; I think it would help to have a couple pictures. Thanks.
