Denso High Torque Starter Performance - Video!
Old Dec 22, 2017 | 08:28 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
I do not... Although, I do have 75 gallons of fuel on board when full, so 781 miles would not be hard to obtain.
Old Aug 12, 2018 | 07:16 AM
Sous's Avatar
Sous
FTE Emeritus
This starter should have longer mounting bolts installed when the starter is installed. The surface of the Denso is nearly twice as thick as the OEM starter and will not allow for the OEM bolts to secure the starter well enough. At least not for my liking...
I have been told that the bolt lengths are the same for the 4R100 as they are for the ZF6 manual.
Please see this thread starting at about post #125.
https://www.ford-trucks.com/forums/1...s-begun-4.html
Old Aug 12, 2018 | 09:17 AM
dn29626's Avatar
dn29626
Is it a two or three bolt?
Old Aug 12, 2018 | 09:23 AM
Sous's Avatar
Sous
FTE Emeritus
It is 2 bolt, the third location is blocked out and is a solid tab. You could drill this spot out and use it as a third bolt location if you choose, but I felt the starter was mounted very securely with the 2 bolts. I can shake the entire truck by checking the starter to ensure it is still tight.
I usually check the starter when I change the oil and give the truck a once over glance while waiting for the oil to drain. I have the Fumoto drain valve, which is very nice to use, but it does take a while for the oil to drain out.
Old Aug 12, 2018 | 02:28 PM
dn29626's Avatar
dn29626
I was going to suggest removing the third bolt and use it as a sample to take to a hardware store and find other bolts.
Old Aug 12, 2018 | 03:13 PM
Sous's Avatar
Sous
FTE Emeritus
That is not required, as stated in the other thread I linked the bolts are M10-1.5 x 45 found at most any hardware store.
dominick2006
Nov 14, 2015 06:24 PM
MUSKRATT2
Dec 13, 2009 11:36 AM
64fordf100292
Dec 26, 2007 07:36 PM
johnnynegaunee
Dec 14, 2005 08:54 PM
