High Torque Mini Starter
Old Nov 13, 2015 | 02:09 PM
dominick2006's Avatar
dominick2006
Does anybody have any thoughts on a high torque mini starter? Having starting problems and a buddy suggested this to me.
Old Nov 13, 2015 | 02:12 PM
Willz74's Avatar
Willz74
Try getting a starter like the 94-96 I'm sure there's more years but I believe that's basically what those are
Old Nov 13, 2015 | 02:13 PM
Freightrain's Avatar
Freightrain
Personally I only use stock starters. What motor are you having problems.
Old Nov 13, 2015 | 09:44 PM
Calypso92's Avatar
Calypso92
Which engine? My best friend works for Denso and converted all of his Fords to Denso style mini starters. He is getting one for my 300 I6
Old Nov 14, 2015 | 12:36 AM
timbersteel's Avatar
timbersteel
If you still have the OE cables, junk them and have some 1/0 or 2/0 cables run to the starter from the battery.
World Of Difference!!
Old Nov 14, 2015 | 04:27 PM
dominick2006
I have 1990 f250 with the 5.8. I have replaced all cables. I took the new 4 ga cable I had just bought for the ground and grounded out the starter with it and replaced it with a 2 gauge cable. I also wrapped the starter DEI heat wrap. The truck has headers but they 're the size of a stock manifold and they don't run down by the starter. I am on the third Oreilly rebuilt starter. The battery that the truck has is a 880 CCA battery.
Old Nov 14, 2015 | 04:50 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Standard or automatic?
You can buy a new pmgr starter for under $50 from DB.
I have one in my truck.
Old Nov 14, 2015 | 05:57 PM
dominick2006
manual what store is DB?
Old Nov 14, 2015 | 06:06 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
DB Electrical is in Kingsport TN.
http://www.dbelectrical.com/c-1439-58-liter.aspx
You can also find them on Ebay and Amazon.
Pretty sure the same starter is used on 5.0 and 4.9's
Just be sure to get the one for a flywheel, because an automatic starter will destroy itself as soon as the engine fires.
Old Nov 14, 2015 | 06:17 PM
dominick2006
I appreciate it.
Old Nov 14, 2015 | 06:24 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Sorry, I should have used this link.
http://www.dbelectrical.com/p-1299-ford-f-truck-bronco-49l-300-6cyl-new-starter-1965-1996-3223-sfd0012.aspx
kupaa
15
May 16, 2012 06:33 AM
fordzilla01
Dec 22, 2009 05:49 PM
MUSKRATT2
Dec 13, 2009 11:36 AM
64fordf100292
Dec 26, 2007 07:36 PM
burny1
Sep 19, 2002 04:11 PM
