Intake Elbow Leak
Old Oct 2, 2017 | 11:52 PM
akblackfoot's Avatar
akblackfoot
Intake Elbow Leak
My Banks Hi Ram seems to be leaking where it connects to the intake manifold. It's been off an on so many times I don't doubt the oring gasket is worn/torn, or something. I'm wondering if anybody knows if the oring is the same as the oem on the Hi Ram, or if not, can I use something else to help seal it? Some kind of gasket maker or silicone? Banks wants like $130 for the small parts kit including the gasket, ridiculous!!!
Old Oct 3, 2017 | 05:01 AM
Yahiko's Avatar
Yahiko
Got a hydraulic store near by? They will have a good assortment or
can make one for you. Because the Banks has to mount in the same
place as the OEM unit it's worth seeing if it fits. It may and that is
what I would hope for.
Old Oct 4, 2017 | 11:02 AM
87crewdually's Avatar
87crewdually
Just saw this. I can let you know later since I have one in my garage. If I remember correctly it uses stock seal. I'll get back later with more.
Old Oct 4, 2017 | 11:36 AM
Justin Jones's Avatar
Justin Jones
Is this it?
2006 FORD F-350 SUPER DUTY 6.0L V8 DIESEL Turbocharged Throttle Body Gasket | RockAuto
Old Oct 4, 2017 | 05:06 PM
87crewdually
That part above looks right. The Banks deffinetly uses an OEM seal. Here's mine with a Motorcraft seal.
Old Oct 4, 2017 | 06:04 PM
akblackfoot
Awesome thanks!!!!
Old Oct 11, 2017 | 12:23 PM
akblackfoot
Got my oring. Is it a bad idea to put a little silicone on it to help seal?
Old Oct 11, 2017 | 12:34 PM
87crewdually
Absolutely no reason to. Its a compression sealed joint. There's only a couple of places a sealant is used on a 6.0 (or any modern engine) and that is not one of them.
Old Oct 11, 2017 | 04:40 PM
Yahiko's Avatar
Yahiko
Dry and it will be less likely to squirt out.
fishermanok
1997 - 2003 F150
Feb 8, 2010 07:08 PM
9d4
Jan 22, 2010 11:20 PM
8525ford
19
Dec 11, 2009 07:37 PM
bigblack302
Mar 16, 2009 03:36 AM
skippydo
Apr 28, 2007 11:22 PM
