intake gaskets
Old Jan 20, 2010 | 11:49 AM
9d4's Avatar
9d4
intake gaskets
putting new intake manifold gaskets on(edelbrock manifold 390) I have it about ready to bolt on, but Ive been reading that people have said not to use the cork end gaskets???? I have them siliconed in place. should I pull them off and just use the silicone??? Why are the gaskets not good to run?
Old Jan 20, 2010 | 12:16 PM
montana_highboy's Avatar
montana_highboy
They're too thick and won't allow the intake to seal to the head properly.
Old Jan 20, 2010 | 01:35 PM
bertha66's Avatar
bertha66
I use them, but I like to seal the bottom side of all the intake gaskets and just sit the manifold down on them and let dry over night. The seal the top and bolt into place. Most people do not like the cork because they slip out of place when bolted down, that's why I do it the way I do. FE engines are bad about leaking at the front and rear intakes.
Old Jan 20, 2010 | 05:24 PM
OrangeJuice's Avatar
OrangeJuice
Yes the FE's intakes are bad at leaking at the front, back and corners. I've had good luck using Right Stuff gasket maker on 3 FE's now. It comes in an aresol can like cheese whiz. I just lay down a nice thick bead, front and back and be sure to get the corners good too. Make sure you get enough squeeze-out when the intake is set in place. Never had a leak using this stuff. It remains flexable and won't dry out. The cork gaskets can dry out and crack, slit and leak like crazy. Good luck.
OJ
Old Jan 21, 2010 | 06:18 AM
Argess's Avatar
Argess
I've used the cork gaskets without problems. Trick is to silicone them down and leave them alone until the silicone sets up.
I don't find the cork too thick unless things are done like decking the block, planing the heads and intake...things that lower the intake manifold from stock.
All that aside, I now do what others do and just use a good bead of silicone and save the cork for the woodstove.
Old Jan 21, 2010 | 02:42 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
It is my understanding that the Edelbrock intake sits too far down to put the cork in there.
I know mine did, but I had the heads milled, both block side and intake side (not the intake itself).
Old Jan 21, 2010 | 11:46 PM
9d4's Avatar
9d4
I just went with the cork, I already had it mostly back together, and wasn't about to tear it apart again. It had the cork gaskets in it before. I also did the silicone them in place and let them sit awhile. So far everything is just fine.
Old Jan 22, 2010 | 07:57 PM
Fighter-of-Wars's Avatar
Fighter-of-Wars
When I used the cork end seals and I RTV'd them they kept the intake raised up to much off the heads to where they didn't seal at all, I removed the end seals and just used a thick bead of RTV on the ends and corners and no problems, I have the edelbrock Performer 390 intake.
Old Jan 22, 2010 | 11:20 PM
montana_highboy
Originally Posted by Fighter-of-Wars
When I used the cork end seals and I RTV'd them they kept the intake raised up to much off the heads to where they didn't seal at all.
I see i'm not the only one who's had that problem.
my-ford
Jan 18, 2015 06:32 PM
asmith6
Nov 30, 2007 09:35 PM
Greywolf
Garage & Workshop
Sep 12, 2006 02:03 AM
original67
May 17, 2004 10:04 AM
74crwcb429hibPS4spd
Jul 18, 2003 05:45 PM
