IDI PUMP TIMING questions
Old Oct 2, 2017 | 11:39 PM
sdiesel's Avatar
sdiesel
k
got an 85 . just put a servicable used pump on, everything works jes fine.
6.9 n/a no mods, but for soup bowl removal.
did i read somewhere that audible detonation under steady state cruise is normal ? or it indicates too advanced pump time?
smoke:
im confusing myself with visible haze on accel but none at cruise, and other signs my pump may need a degree or two of tuning
starts real well has fabulous power, and dont smoke.
comments pls?
detonation seems to be even on all 8 cylinders
thx all
Old Oct 3, 2017 | 10:45 AM
cadunkle's Avatar
cadunkle
Set it to 9* at 2000 RPM using the pulse method. 8.5*-9.5* is in the ballpark for best performance and economy while staying safe. Much less than that and you're sacrificing low end torque and it'll likely get smokey (gray/white), but may spool faster or build more boost (not applicable to you). You can go as high as 10* before you start damaging glow plugs. A few degrees more and you're getting hard on rod bearings and creating a lot more pressure in the cylinders (head gaskets).
Old Oct 3, 2017 | 10:48 AM
sdiesel's Avatar
sdiesel
k thx.
i have none of the tools necessary for this.
Ross diesel does, but is very booked right now,
and im not finished with mods b4 going in there.
sooo, is there telltale signs that im in the ballpark or our of the park altogether?
Old Oct 3, 2017 | 06:21 PM
Franklin2's Avatar
Franklin2
If you want it ballpark, find the cold advance wire that goes to the pump. You should have two wires to the pump, one is the fuel solenoid to make it run, and the other is the cold start advance wire. There is a sensor in behind the alternator that activates this wire till the engine warms up, and it also activates a solenoid on the throttle to make it fast idle till it warms up.
Get the engine totally warmed up, you know these engines never warm up just sitting in the driveway, so take it out and run it.
Come back and with it idling, jump power to the advance wire. You should hear what they call the "powerstroke rattle" when the advance wire is powered. Take power off and it should go away.
If you hear the powerstroke rattle all the time, you are too advanced. If you never hear the powerstroke rattle when the wire is powered, you are too retarded. When you can turn the powerstroke rattle on and off at will with the wire, you are about right.
Old Oct 3, 2017 | 06:25 PM
cadunkle's Avatar
cadunkle
Get the pulse timing adapter, they're not terribly expensive. Ferret Instruments V765-01 Injector Tester - Fuel System Tools
You cannot set timing without either this adapter and a dial back timing light (Actron CP7529 Timing Light - Electronic Testing) or a luminosity type timing tool. These are required tools if you own one of these trucks. For what you pay someone else to do the job once you can probably buy the tools and be set for life. I check/set timing annually, realistically you should probably do this at least every 30k miles or so.
Old Oct 3, 2017 | 06:33 PM
Franklin2's Avatar
Franklin2
I guess he knows that messing with/replacing the injectors messes up the timing also.
Old Oct 3, 2017 | 10:51 PM
sdiesel's Avatar
sdiesel
i did NOT know that.
Old Oct 3, 2017 | 11:01 PM
sdiesel's Avatar
sdiesel
ok so im set up with these tools (suppose) i time it off the harmonic balancer?
i guess at this point i can check my FSM for details.
but thx fer the illumination. not punning.
and if my harmonic balancer has slipped..... which i hear is common on these engines due to vibration, leads me back to seat of britches guessing. or a new harmonic banancer.
which leads to another question
is the balancer set straight up or clocked for emissions somehow. maybe that is nonsensical but thought i would ask.
i noticed tonite in the headlights of the car behind me that hard accelerations produces some visible exhaust emission but its not visible from the cab or mirrors, so im hoping im within acceptable norms there.
gents your helping here don't give up ill get it quick enough. my thing has been the 6bt.
thx
Old Oct 3, 2017 | 11:48 PM
grumpin's Avatar
grumpin
How does that mess up the timing?
I had an 88 with the 7.3, I did like sdiesel and replaced it. Then took it to a mechanic that could time it. I asked if it was close and he said not really.
Old Oct 4, 2017 | 12:51 AM
matthewq4b's Avatar
matthewq4b
The injectors are calibrated to spray (pop) at a certain PSI this is controlled by spring pressure in the injector. As injectors age the springs settle and the pop pressure changes ( gets lower) and the timing advances. You need to take this in to account and it is actaully a good idea to retard the timing a bit on brand new injectors cause as they settle in timing will advance. So this is why timing calibration needs to be done/checked every X number of miles/hours on mechanically injected diesels or if the injectors are swapped out. I'm fortunate and have the Ford/Rotunda Timing tools for the 6.9 and 7.3L so setting the timing on these engines is a 20 min job for myself.
Old Oct 4, 2017 | 07:18 AM
cadunkle's Avatar
cadunkle
Check condition of the rubber. If it's cracked, squeezed out, or generally appearing in bad condition the damper is suspect. You can verify approximate position of the keyway on the crank and balancer in relation to timing mark, and the position of the IP gear dowel and bolt holes. You'd be hard pressed to notice a couple degrees but if it's really far out you'll see it.
Old Oct 4, 2017 | 10:24 AM
sdiesel's Avatar
sdiesel
THANK U!
for this.
Old Oct 4, 2017 | 11:23 AM
grumpin's Avatar
grumpin
Thanks, I did not know that. Very interesting.
Eric Kropp
Sep 15, 2014 04:34 PM
banicman
Dec 4, 2012 10:42 AM
muscletruck7379
Oct 6, 2010 09:31 AM
dyoungen
Dec 24, 2009 12:18 PM
brownjc29
Mar 23, 2004 05:08 PM
