2003 sport trac power window problem
Old Sep 15, 2017 | 01:34 PM
bnew158's Avatar
bnew158
The left rear power window quit working. I took the panel off, couldn't find anything obviously wrong, put it back together and the window worked perfectly. From the left rear door switch and the driver's door switch. But the door lock was now frozen. I couldn't even budge it manually. I took the panel back off, pushed the pin down into the locked position, and the door lock started working again. But now the window won't work again. I have no idea what's going on. Any suggestions?
Old Sep 17, 2017 | 09:00 AM
steve(ill)'s Avatar
steve(ill)
is there a child proof window switch on the side of the door that you are moving... or wires to it inside that are being "moved".
Old Sep 17, 2017 | 09:13 AM
bnew158's Avatar
bnew158
Lock
There is a child lock. To my knowledge, I didn't touch anything associated with it. However, an hour after the original post, I went back out to my truck and everything is working. I replaced no parts, but now the window and the lock both work. Gremlins? I'm completely baffled.
krehjc
Paint & Bodywork
Jun 14, 2011 05:42 PM
kent521
Feb 22, 2011 11:28 AM
shift1313
Jul 9, 2005 10:53 PM
jamyboy
Mar 5, 2003 07:42 PM
Orenstein
1978 - 1996 Big Bronco
Nov 14, 2002 02:00 AM
