Power Window / Door Lock
Old Feb 22, 2011 | 10:38 AM
kent521's Avatar
kent521
I bought a 96 cc the window & door locks will only work a the drivers door . I thought it was the window lock stuck at first but then noticed that the door locks also didnt work . I checked the fuse box and pulled the window switch on the front pass and had 12volts at the door lock switch but not the window . What could be causing this , and could it be a bad driver door switch ?
Old Feb 22, 2011 | 11:28 AM
DIYMechanic's Avatar
DIYMechanic
Sounds like a bad switch to me. Sorry I just re-read your post and it sounds like everything works from the driver's door but not the passenger door? If that's the case and the window and lock still work, it sounds to me like a bad switch.
