Drum brake question
Old Sep 7, 2017 | 11:03 PM
wizzy214's Avatar
wizzy214
Drum brake question
99 e250 ext cargo
going to change the drum brakes. Never looked at them before. Had van for 10 years changed front twice.
What size are they 2 1/2 or 3 inch??
do I need to replace all the springs?
Shoes type prefrence?
1st time drum brakes what should I not do. Been watching YouTube vids.
thanks for the help
Old Sep 8, 2017 | 12:09 AM
jbwheels's Avatar
jbwheels
Do only one side at a time so you have the other for reference.
Might even take a few pictures before you take one apart.
Spring kits are cheap enough I just replace them. My theory is it helps keep the self adjusters working right.
Make sure the adjusters thread in and out smoothly.
I like to put a thin film of grease on the pivot points and where the shoes rub on the backing plate. You'll see the shiny spots.
I hate drum brakes.
Hard to believe they're cheaper to make than discs - which would be the only reason OEMs still use them.
Old Sep 23, 2017 | 01:06 PM
wizzy214's Avatar
wizzy214
Just replaced the shoes and wheel cylinder, all new springs and hardware. Hopefully no one noticed broken lug.
Old Sep 23, 2017 | 03:15 PM
vettex2's Avatar
vettex2
well that was the time to change it
Old Sep 23, 2017 | 03:23 PM
Tedster9's Avatar
Tedster9
Supposedly, has to do with the higher cost or complexity of the parking brake mechanism with disc brakes.
Old Sep 23, 2017 | 07:38 PM
wiskeyVI's Avatar
wiskeyVI
Look at the stack o' springs on that thing!
joegeds
May 31, 2016 08:11 PM
Halloran1
Dec 18, 2011 11:35 PM
marks500
16
Sep 18, 2011 11:09 PM
Not Steve
Jul 29, 2010 10:55 AM
sharkdance
Mar 15, 2005 09:23 PM
