Brake Question
Old Jul 27, 2010 | 06:40 PM
Not Steve's Avatar
Not Steve
Brake Question
It's not the typical disk conversion question, I'm actually leaning toward keeping all the drums on. The question is on a '66 F 100 do the drum brakes automatically adjust themselves?
Old Jul 27, 2010 | 07:15 PM
Bill W's Avatar
Bill W
In a word YES, but they did not work all that good.
Old Jul 27, 2010 | 08:04 PM
Not Steve's Avatar
Not Steve
One of mine does, the right front seems to work great unfortunately the rest are slacking on me. If you some body stops short in front of you and you gotta stab'em hard, you'd better be haning on! Guess I'll take them apart and clean/inspect and see whats going on. Thanks much, Scott.
Old Jul 27, 2010 | 08:46 PM
Broomfieldbum's Avatar
Broomfieldbum
Hey Not Steve,
I left the drum brakes on my 66 and put all new parts all the way around, springs and all. The one thing I learned from NumberDummy about the adjusters is they only work in reverse. So once you get the brakes all in good shape you need to back up, and hit the brakes a couple of times to adjust them. I think I spent a total of $350.00 and replaced all cylinders, shoes, springs and drums. Not to bad for knowing I can stop.
Old Jul 27, 2010 | 09:01 PM
garbz2's Avatar
garbz2
And you can put them in basakwards! so be careful and do one side at a time.
Is not fun auto adjusting the brakes out every time you stop and it gets harder to stop..........My dad was PEEVED to say the least. Hey i was 11...
Garbz
Old Jul 28, 2010 | 04:11 PM
Not Steve's Avatar
Not Steve
A couple years ago I did all four drums, shoes, wheel cylinders , and rubber lines. The springs and such looked to be OK so everything got cleaned up and bolted back on. They worked pretty good so I left them as is, it didn't get driven much so it was fine. Now, however, it's back from the machine shop and the ole 300 has been done up pretty nice and it gets driven more so it needs to be able to stop. I guess sitting idle for a year or so isn't so good for them.
Old Jul 29, 2010 | 10:55 AM
rust muffin 66's Avatar
rust muffin 66
The brakes on my 66 had been replaced before I got the truck and work great I adjusted them once because the truck hadn't been driven for a year or so before I got it. If I want to stop I hit the brakes if I need to stop fast I have to pump them once to get a little more pressure and sometimes again if they lock (rarely) I mostly just drive with the mindset of what can or will fail today and how do I avoid wrecking as long as you know what you have to do or might have to do and don't panic you should be fine also use engine braking to keep the stress off bad brakes.
lauxg
13
Jan 21, 2021 02:02 PM
finneys98xj
Apr 12, 2012 02:12 PM
awhtx
Large Truck
Mar 25, 2010 01:35 PM
Broken40
Aug 19, 2007 06:00 PM
gary_b
Oct 16, 2006 07:46 AM
