LED Headlight conversion
Old Sep 7, 2017 | 09:51 PM
sheepdog360's Avatar
sheepdog360
Originally Posted by Vanquish Auto
By the way we did a similar test on the 2018 F-150 and took a full video actually showing the lux test meter readings. As you can see the revolutionaries didn't show it.
Those headlights he chose as top performers have less than half of the performance of our LEDs and at least a good 2 year older compared to ours.
If I may suggest a true alternative to the halogen bulb I would go with a true bixenon canbus hid system. No problems with the Drls, no problems with scattered light on low beams and certainly won't complain about the high beams and it's truly the brightest at 20ft away will put 150% increase over the LEDs and 311% over halogen. The biggest difference between the led kit and hid is that the hid will still give you a good light output and at 120ft the hids will have a 200% increase over the led and whooping 3200% increase over halogen. At 180ft away the increase from hid to led is 600% and the halogen Does not produce any lux after 120ft.
https://youtu.be/M9_Fg42lASo
not that Im disputing your claims or knowledge. By chance while testing F150's did you test Super Duties? Do you have a video or pics for comparison of your recommendation to what was posted?
I ask because it would definitely help me make a better informed decision
Old Sep 7, 2017 | 11:09 PM
DuRsT's Avatar
DuRsT
Originally Posted by Redrockerstl55
I was able to snap a couple pics tonight of my Supernova V3's
I was parked on this road so I was in the same position for both the low beam pic and the high beam pic. The grassy sides of the road slope upwards on both sides.
To me side to side visibility is great. The light from the 4 headlights is pretty focused on the center of the road and then is spreads out from there. I have not yet been flashed by oncoming cars so although these bulbs are very bright the light is focused in the right places.
Low beams...light is even and nicely spread out.
High Beams...light is still even, nicely spread out but those trees are really lit up in the background. I would guess those trees are about a 7 or 8 iron away.
Looks really good man, really good.
Can't wait to hear if you have any quirky issues...if not I'll pull the trigger myself.
Old Sep 17, 2017 | 01:23 PM
Rasty1's Avatar
Rasty1
Just installed mine yesterday. Have to say, they are night and day (pun intended) better then stock bulbs!
Old Sep 21, 2017 | 06:14 PM
dbrunson's Avatar
dbrunson
Do you still get full factory function? Auto,DRL etc. I'm trying to decide if they are worth the money compare to upper end Halogens.
Old Sep 22, 2017 | 07:12 AM
Redrockerstl55's Avatar
Redrockerstl55
I have been running the LED's 100% of the time with the DRL's on...zero issues. They just work.
Headlights are fantastic. The auto high beam with the LED's is a game changer. Zero issues.
The auto on function works just like the factory set up also.
Last night I ordered more LED's from Headlight Revolution. I picked up their Fogs and chose the plug and play version. They are the fog version of my headlights. I also bought the LED's for the pretty dim license plate lights.
If this goes well then my next steps will be to convert the tail lights and reverse lights.
Old Sep 24, 2017 | 08:57 AM
mtnbkr's Avatar
mtnbkr
In post #8 you said you had ordered fogs from Vanquish, did you change your mind and go with HR? Curious, because I got headlights, turn sigs and fogs from HR and will try to install today.
Old Sep 24, 2017 | 10:13 AM
Redrockerstl55
I tried to get fogs from Vanquish.
I just placed an order for fogs from HR (Headlight Revolution). Supernova V3’s to match my headlights. I also bought the license plate LED’s and hopefully can get those installed this week.
If all that goes well then I will do the tail lights and reverse lights.
Old Sep 24, 2017 | 01:43 PM
Vanquish Auto's Avatar
Vanquish Auto
Former Vendor
Originally Posted by mooch91
^ This.
I'm struggling with the inconsistent reviews and feedback on any of the LED replacements I've seen to feel comfortable buying a set, regardless of the price. I just don't know if these replacement bulbs are ready for prime-time.
They are not, and they are far from that. We went ahead and put together the best kit you can throw at this truck. It's a particular type of canbus system that can work with drls and will give you the right beam cutoff and excellent high beams.
It's unbelievable to see companies like headlight revolution putting up fake numbers on usable light from those led bulbs. I can assure you the output gets reduced by 1/3 to 2/3 from the halogens. The point of upgrading should not be just for color.
Here is a test video we took for 2018 F-150 at 80 ft away, and this is why a high-end led kit. I wouldn't even waste my time of adding the headlight revolution into the equation unless I get enough requests:
And here is a quick walkaround of the 2017 SD with the HID system we put together for this truck, it's bulletproof and a TRUE UPGRADE to the halogens. Don't mind the color of the lights, for some reason the phone took the video and the color was off completely.
Old Sep 24, 2017 | 01:46 PM
Vanquish Auto
Former Vendor
The auto on function works just like the factory setup also.
Last night I ordered more LED's from Headlight Revolution. I picked up their Fogs and chose the plug and played version. They are the fog version of my headlights. I also bought the leds for the pretty dim license plate lights.
If this goes well, then my next steps will be to convert the tail lights and reverse lights.
Is it possible you could do a side by side comparison? I can send you a kit that you can return afterwards. We will take care of the shipping back and forth. It will help the forum a lot.
Old Sep 24, 2017 | 03:09 PM
Redrockerstl55
Actually no I am not interested.
I have no way to measure the light output of the V3’s I bought from Headlight Revolution but the lighting in my photos is very accurate for color and you can certainly tell they are significantly brighter than stock. I was sent the correct bulbs promptly and they worked perfectly from the get go.
Do you know how I can get a refund for the incorrect fogs I was sent by Vanquish. I can’t get anyone to return my phone calls or emails. I am only interested in a refund at this point. Thank you.
Old Sep 24, 2017 | 04:20 PM
Vanquish Auto
Former Vendor
please send the lightsbbadj. We will process a refund as soon as they arrive. We got hit by the hurricane and had no utilities for over a week.
Old Sep 24, 2017 | 04:47 PM
user 474747383's Avatar
user 474747383
Your Pic's look very good I think I'm sold, Thanks for the Post of the Low & High
Old Sep 24, 2017 | 05:02 PM
  #28
Redrockerstl55
please send me a return address label. You guys sent me the wrong bulbs. I emailed and chatted with Jessi and he said you guys were not effected by the hurricane. His cars were safe in the garage. Thanks.
Old Sep 24, 2017 | 06:42 PM
  #29
Vanquish Auto
Former Vendor
thats correct but we spent over a week without work and limited internet from phone and no electricity.
Old Sep 24, 2017 | 07:28 PM
  #30
Redrockerstl55
Let’s take this offline. I will send you a PM.
