should I be worried?
Old Sep 5, 2017 | 11:55 PM
Karlow's Avatar
Karlow
So I have a ticking sound that has me puzzled.
I thought it could be coming from the drivers side of the engine.
This weekend, actually on Monday I decided to do the hot re-torque on the diver side. I warm up the engine for about 15min and have at it. I had put this off for weeks because it has bee way too hot. Dam it was still too hot, I was sweating buckets. I had to stop several times to clear the sweat off my head my eyes my shades.I torqued everything to spec and nothing moved. I went to 125 inch lbs and I got movement on the rear two injectors. I gave them about 1/2 a turn and stopped. I put everything back together, I used hair spray form the 99 ct store. It seemed OK.
Fast forward to Tue. I needed to be sure so I went for the boost leak test. Here is my concern. I was going to test to about 30 PSIG, but I ended up at about 40 psig and I forgot to disconnect the MAP sensor! How likely is it that I damaged the sensor, and how can I tell? She is pretty stock and does not have a boost fooler to protect the sensor.
What do you think? Nothing popped and I did not leave the the HP on very long.
Old Sep 6, 2017 | 03:40 PM
JT250's Avatar
JT250
probably fine
Old Sep 6, 2017 | 04:18 PM
brian42's Avatar
brian42
Veteran: Navy
I hear that the 38R turbo is good for 40psi and I haven't read that anybody swapped MAP sensors that has one so I think you're fine as JT250 said.
Old Sep 6, 2017 | 04:56 PM
Karlow's Avatar
Karlow
Thanks guys, that just one less thing to be concerned about!
Old Sep 7, 2017 | 02:57 PM
Bonanza35's Avatar
Bonanza35
Rich had to replace his, he then put the boost fooler back on to protect it. GH use to have different map sensors but haven't heard this for years. I think they mainly used them for better tuning.
Old Sep 8, 2017 | 07:04 AM
Tugly's Avatar
Tugly
If you use a different MAP sensor, you can recalibrate the tune to actually read boost in excess of the stock max of 32-33 PSI at sea level. If you live in Denver, you can read up to 35-36 PSI boost on the OBDII port with the stock MAP sensor.
Cody and I once talked pretty deeply about a "revised" MAP sensor that could take a bigger beating without the aid of a boost fooler. About all it really does for you is it allows the OBDII port to see the actual boost - nothing to be gained in tuning, and pulling the chip leaves you with a funky MAP sensor that doesn't work with stock tuning.
I added a bigger analog boost gauge in addition to the OBDII boost gauge, plus I have the boost fooler for the MAP sensor. I watch the OBDII for daily driving - where the analog is strictly to see if the boost system is up to 100% while passing pokies.
53jimc
Nov 19, 2018 06:53 AM
Mike2006 powerstroke
Mar 12, 2016 02:19 PM
pullinair
21
Sep 30, 2008 06:29 PM
bobrc
Aug 24, 2008 12:56 PM
444dieselrod
Feb 20, 2005 07:15 PM
