New distributor installation question
Old Jul 7, 2017 | 05:44 PM
PaxtonQ's Avatar
PaxtonQ
Truck:
1972 f250 2wd 390FE C6 auto
Hi all I purchased a new (remanufactured) distributor from napa auto parts and it came with a single wire coming out of the side whereas my old one had 4 wires wth a connector on the end so I pulled the other end of the plug off of my coil which is where it led and was connected to + and - side. I initial assumed the wire on the new distributor was a ground but now I seen to be getting no spark... could this wire not be a ground? P.S. All spark plugs, ignition coil, distributor, cap, and rotor are brand new. And truck was running and driving before the distributor took a ****.
Old Jul 7, 2017 | 06:23 PM
Tedster9's Avatar
Tedster9
Distributor grounds through the engine block. The condenser is wired in parallel with the points, one end of the points connects to the (-) NEG terminal of the coil.
Old Jul 7, 2017 | 06:34 PM
KULTULZ's Avatar
KULTULZ
Post
Originally Posted by PaxtonQ
Truck:
I purchased a new (remanufactured) distributor from napa auto parts and it came with a single wire coming out of the side whereas my old one had 4 wires wth a connector on the end...
Sounds like the previous owner did a DURASPARK upgrade and they gave you an older points style dist.
Old Jul 7, 2017 | 09:26 PM
PaxtonQ's Avatar
PaxtonQ
Thank you I will try that in the morning... currently charging the battery it didn't like all the cranking
Old Jul 7, 2017 | 09:28 PM
PaxtonQ's Avatar
PaxtonQ
thats what it looked like to me but the dang electronics got in the way of my removing the vacuum advance canister so I ended up needing a whole new distributor
JosePrado
Sep 7, 2017 11:56 AM
Lola's Panel
Sep 28, 2014 01:25 PM
daniel1982
Apr 26, 2011 04:41 PM
austin.dockter
Nov 19, 2008 03:39 PM
Tedster9
Aug 2, 2002 03:22 PM
