New HEI distributor question
Old Nov 5, 2014 | 07:10 PM
jswisc's Avatar
jswisc
I have a 1987 460 w/ carb. I was having some issues with getting spark and after working on it for awhile I decided to replace the ford ignition system with a new HEI distributor. I has a self contained coil and all you have to do is run 12 volts to it and you're good. Trouble is, there are 2 tabs that input into the distributor..The directions just say run keyed hot to the distributor. I assume one is 12v and one is ground. But I don't know which is which. Does it matter? If it does, anyway I can test which is which? I am going to call the seller tomorrow. Thanks.
Old Nov 5, 2014 | 09:37 PM
jswisc's Avatar
jswisc
Nevermind. Printing was a little small so used a magnifying glass, Batt-tach.
Old Jul 10, 2022 | 09:45 AM
bronco kenny's Avatar
bronco kenny
Put a HEI from JEGS in my truck after having trouble with stock duraspark system. Seems to have alittle more powerand runs great so far.Only thing I had to do was get a smaller air cleaner to fit from k&n
Knockonwood
May 21, 2019 03:51 PM
JosePrado
Sep 7, 2017 11:56 AM
CaptainJohn
17
Sep 18, 2016 04:39 AM
1950ford
Dec 16, 2007 10:15 AM
ScottDora
Feb 28, 2000 05:13 AM
