Need Help with power stroke
Old Sep 2, 2017 | 10:12 PM
jsoracco's Avatar
jsoracco
My F250 stop about 20 min of use, Mechanic said change fuel filters and I did it. Was a big change but after about 15 min star to shaking and them stop. I have to wait about 15 min and star normally but the cycle repeat again and again. Any ideas?
Old Sep 3, 2017 | 12:30 AM
DarkStarMedia's Avatar
DarkStarMedia
Likely a high pressure oil system leak. You need a way to get live data to be sure.
Richard
Old Sep 3, 2017 | 11:03 AM
jsoracco's Avatar
jsoracco
Thanks Richard, but my hight pressure oil pump is new. I want to find out if a diesel pump is electrical and can be overheated and can be the cause to stop sudendly. Like I said after about 20 min runs normally but the cycle repeated again and again.
Old Sep 3, 2017 | 11:22 AM
DarkStarMedia
What year is it? If it's a 05+ then hpop failure is extremely rare. If its an 03-04 and you got the pump from Ford.... Could still be the pump. As I said, it is most likely a leak.
What year is it?
EDT: there is a electronic fuel pump module but they seem to work or not and failure is rare (it's on the fuel rail). You issue is classic of a high pressure oil leak.
Get a Bluetooth elm327 and torque pro for your phone and get some live data during failure. I am betting your icp and IPR will drop off when it fails
EDT2: post your location as there may be someone in town who can help
EDT3: be sure you are using only motorcraft filters and post a pic of your oil filter cap... If it's aftermarket is can cause engine damage
Old Sep 3, 2017 | 11:31 AM
69cj's Avatar
69cj
Are you sure the fuel tank isn't contaminated?
Old Sep 3, 2017 | 11:34 AM
jsoracco's Avatar
jsoracco
It's 2004. Pump it's brand new original Ford. Problems looks it's about overheating a module or something else that do not send fuel and stop it.
Old Sep 3, 2017 | 11:58 AM
jsoracco's Avatar
jsoracco
Yeap, I going to check the tank. Tanks
Old Sep 3, 2017 | 05:38 PM
bismic's Avatar
bismic
Might want to do a bubble test
Old Sep 3, 2017 | 07:18 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
You may have blown top injector seals or a leaking o-ring on top of the discharge tube on the HPOP. The only way to tell is if you use the air through the IPR or the ICP sensor hole.
Old Sep 3, 2017 | 08:03 PM
bismic's Avatar
bismic
Since they are easy to do, I would verify the ICP pressure, ICP volts, and IPR% duty cycle (and check for bubbles in the fuel) before doing more involved testing. Get the ICP and IPR data when cranking - after it shuts down and won't re-start.
naturescape
Oct 19, 2010 06:31 PM
FORD MEGA CAB!!!
Jun 27, 2008 07:38 PM
izzybird
Texas Chapter
May 9, 2007 11:07 PM
loserpdenton
Feb 3, 2003 08:31 PM
traxdude
May 24, 2000 04:27 AM
