Gasoline Leak
Old Feb 3, 2003 | 05:30 PM
loserpdenton's Avatar
loserpdenton
Question Gasoline Leak
I have a gas leak in the front of my 75 Ford F100 w/302. I have seen similar postings that say it is probably the fuel pump, but it looks like it is coming from a fuel pressure sensor next to the fuel pump. I don't know if the sensor came stock with the truck or it was an add-on. The gas is definitely coming from that area, because it is spraying against and dripping off of the oil filter. Any suggestions would be greatly appreciated.
Old Feb 3, 2003 | 06:17 PM
Mil1ion's Avatar
Mil1ion
Gasoline Leak
The oil pressure sender on a 302 is down near the fuel pump & oil filter.
I would suggest the fuel pump is the problem.
Old Feb 3, 2003 | 08:31 PM
loserpdenton
Gasoline Leak
You're right; it's the oil pressure sensor. After more careful observation, it is coming from the pump. Any suggestions for a pump brand? I'm willing to order online if I have to.
