Starter engaged on incline
1950 M68 with 239; converted to 12V; with S10 transmission.
Has anyone experienced the starter staying engaged only when you are going up a hill? We've got the truck out on first test runs, and this seems to be consistently happening. The starter works well to get the engine going, and on the flat or going downhill it's ok. Kind of weird. Looking for ideas.
We've pulled it out and will have a look at it over the weekend - we should do that anyway I suppose since this was one component we had not done anything to at this point, and as far as I know it's the original starter.
Hey cowdog86 that's also worth tracing back. It's all new wiring including the starter button but that doesn't mean it's done perfectly! What I don't understand is why it only happens on downhill runs if it is wiring. Maybe I missed the part in physics where electricity runs downhill?
If it happens only when you go uphill, then that pretty much lines it out to a physical position thing. A bare spot on a wire that touches a wire clip when going uphill , etc. Or the cheap Chinese made starter button is completing the ground when.going.uphill. Do this. Remove starter button. Ground the wire to start it . Throw a piece of tape around the end and go drive uphill.. I bet the starter button is faulty is my guessay from way up here.
i'm guessing a bad return spring on the starter bendix. had the same problem awhile back. down hill it would engage a little. up hill no problem. get access to your starter gear and see if you can move it out by hand easily (ground cable off of course) if you can the spring is bad and time for a new starter.
Fun times. Good news is that everything else seems to be working well as far as we can tell, and with all the new parts that's promising.
heavy_d
16
03-21-2014 12:21 AM
mOROTBREATH
18
09-24-2013 07:01 PM
