New member, trans issue
Old Aug 28, 2017 | 10:33 AM
IWH's Avatar
IWH
Hello, new to the forum, have a question that some one may be able to help with.
1995 f250 7.3 4x4.
121k miles.
Kind of of a weird problem but, not thinking it is a big problem.
The other day, went to the dump (10 minutes away from my house). Truck shifts normally, get to the dump, put truck in Park left it running and unloaded trash. 5 minutes at the most.
Put in drive and while leaving, truck will start strong but, will not shift into second. It will rev high with limited power, I let my foot off the pedal, Rpms drop to idle, while still moving I step on accelerator and nothing. It just revs.
I then shifted into 2, got power. Left it in 2 for 10 seconds, shifted back to drive and it shifts normally.
This happens when I drive long distance, short distance and whether I let it idle for a while or shut it off briefly.
When I replaced the water pump a few months ago, I had the guy do a scan( with the proper tool) no codes.
I replaced the speed sensor, no help.
It it does have a led strip light connected to the brake lights.
Thanks.
Old Aug 28, 2017 | 10:52 AM
z31freakify's Avatar
z31freakify
Remove the LED light and try it, LED males the TC not lock not sure thats yoir problem but worth a shot hopefully Mark K. Can shime in give his knoweledge about the problem.
Old Aug 28, 2017 | 12:47 PM
Jarrett Campbell's Avatar
Jarrett Campbell
How is your trans fluid level?
Old Aug 28, 2017 | 12:52 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
LEDs cannot cause no shifts. That's not the problem.
The first thing to do is check for codes. I know there were no codes a while ago, but that doesn't mean anything today.
Old Aug 28, 2017 | 01:01 PM
Hussler's Avatar
Hussler
These 7.3 transmission dip sticks are the hardest to read, both on my 97 and 99. Even in bright light it is hard to determine where the fluid level actually is. That stupid white bulb at end of the dip stick stick doesn't show up clean red transmission fluid very well. Very easy to overfill - underfill, ask me how I know, lol.
Old Aug 28, 2017 | 02:00 PM
IWH's Avatar
IWH
The problem was happening back when the water pump was done, that's why I had him scan it.
I will contact him and most likely I can drop by and have him check again.
Fluid is bright red and appears to be at the correct spot on the dipstick.
It has a high capacity transmission pan and temp runs 160-165.
Thanks for the replies.
I will let you know what the scan says as soon as I get it done.
Old Aug 29, 2017 | 08:37 AM
IWH's Avatar
IWH
Had the ecm scanned last night, no codes.
He used an AutoEnginuity scan tool.
not sure where to go from here.
Old Aug 29, 2017 | 08:51 AM
Mark Kovalsky
Can you use the AutoEnginuity to look at data? Specifically, what does the PCM show for vehicle speed when this happens? I suspect a problem with the PSOM not sending vehicle speed to the PCM.
Old Aug 29, 2017 | 09:28 AM
IWH's Avatar
IWH
I don't know anything about the tool.
Didn't check while driving, just hooked it up to check for trouble codes.
One thing ink I forgot to add. The first couple times this happened, I would pull off, hop under the truck and pull the connection to the speed sensor.
Plug it back in, start the truck and it would run normally.
Old Aug 29, 2017 | 11:57 AM
z31freakify
Probably the wires going to the VSS or the connector have corrosion. Replace the pig tail.
Old Aug 31, 2017 | 08:12 PM
mcali2's Avatar
mcali2
Do as I do. replace everything..
Old Aug 31, 2017 | 08:19 PM
IWH's Avatar
IWH
Done that before and usually doesn't fix the real issue.
Drove her today, with more stops/starts/idling than I have since I bought her.
No problems whatsoever, I will finally have some time to trace some wiring and look at connections tomorrow.
Old Sep 2, 2017 | 05:16 PM
IWH's Avatar
IWH
Haven't been home enough to get underneath yet but, here are a few pics.
Devilmanak
18
Apr 7, 2013 05:48 PM
six6six
Nov 5, 2011 02:00 AM
roos3342
Oct 19, 2007 09:17 PM
rockfish123
Jun 25, 2007 04:32 PM
bigfoot4iwov
Aug 1, 2003 04:09 AM
