Need Help cant fix problem!!!!
Old Jun 25, 2007 | 10:12 AM
rockfish123's Avatar
rockfish123
I own a 1996 FORD F250 4X4 SUPER CAB 7.5 LITER GAS E4OD AUTO TRANS with 187000 mileage on it. Check engine light came on started shifting hard and stalling. Replaced FUEL FILTER PLUGS CAP ROTOR O2 SENSOR. Had engine scaned by local garage said THROTTLE POSTION SENSOR BAD. Had it replaced and set. Still problems TRANS SHIFTS HARD and STILL STALLS. Took it back scaned it again NO CODES CAME UP. Replaced a FUEL PRESSURE SWITCH/VALVE. STOPED THE STALL PROBLEM. STILL HAD IDLE ISSUE WITH IDLE SPEED SO WE REPLACED THE IDLE AIR CONTROL VALVE. Idle stays steady but is still high also HAD INJECTORS CLEANED ON THE TRUCK WITH INJECTOR CLEANER ON A MACHINE/TOOL AT THE RAIL. Still have shift problems first and second gear shifts early third gear and over drive shifts late. CHANGED FILTER DRAINED TORQUE CONVERTER AND REPLACED FLUID. Check ENGINE LIGHT IS STILL ON NO CODES COME UP TRANS SHIFTS HARD SHIFTS EARLY SECOND AND THIRD GEAR AND LATE IN TO OVER DRIVE, DOWN SHIFT ON HILLS WITH NO LOAD. What to look for or go to next puzzled.
Old Jun 25, 2007 | 10:40 AM
385seriesHemi's Avatar
385seriesHemi
Whats the transmission fluid look like? does it smell burnt?
Old Jun 25, 2007 | 10:42 AM
Bruce R Leech's Avatar
Bruce R Leech
reset the computer and check for codes after you drive it one day.
Old Jun 25, 2007 | 11:02 AM
Scndsin's Avatar
Scndsin
How are the codes being checked? Something should be showing with all that you have going on.
Check grounds and reset as Bruce sez.
Might be time to start looking at pcm/ecu.
Old Jun 25, 2007 | 12:06 PM
rockfish123
When i changed the transfluid it was very discolored... It smelt a little burnt too.. But there was no shavenings in the pan only an only a few on the magnetic. As for the codes.. None come up anymore.. At first a few came up and i changed the throttle postion sensor and the O2.. But since than the machine dosen't pick it up.. Well the codes are being checked with a snapon brand tester that my friend at the local garge owns..
Old Jun 25, 2007 | 12:16 PM
95Ford4x4's Avatar
95Ford4x4
i don't see how the engine light can be on without any codes showing up, did you clear the codes and disconnect the battery for a few minutes??
Old Jun 25, 2007 | 12:18 PM
rockfish123
Also the engine light is still on. It will turn on and off.. But most of the time it is on.. There still is somewhat of a low end idle problem.. The idle isn't constant and will stay at 1,100 rpm when it should be at 600-700 rpm..
thanks rock
Old Jun 25, 2007 | 12:21 PM
rockfish123
Yes I have did that several times.. And now nothing will pick back up? The computer has been hooked up 3 or 4 and still can't pick anything up.
Old Jun 25, 2007 | 12:23 PM
385seriesHemi
On late 94 - present models just disconnecting the battery will not work because on OBD2 systems you need a computer diagnostic tool to clear the codes. When it shifts hard do you mean like a big clunk? because just shifting firm is not a bad thing.
Old Jun 25, 2007 | 12:53 PM
subford's Avatar
subford
Check your VSS on the rear axle.
Old Jun 25, 2007 | 01:03 PM
rockfish123
Yeh when it shifts it is a big clunk. One clunk around 10 another around 25 anther around 35 and another sround 50 depends on how hard you step on it...
Old Jun 25, 2007 | 04:16 PM
95Ford4x4's Avatar
95Ford4x4
was this the first time you've ever changed the tranny fluid and filter??
Old Jun 25, 2007 | 04:26 PM
385seriesHemi
Another thing is the clunk can be the rear Ring & pinion gears having too much clearance also, my dodge ram has that. Also your driveshaft U-joints can be bad too so both of those can be a culpret for the clunk too.
Old Jun 25, 2007 | 04:28 PM
385seriesHemi
Those speeds you posted are around the regular shift points, first is a tiny bit early but the other 2 are where they are supposed to be. Regular throttle is 1= 12 - 15 mph, 2= 23 - 27 mph, 3 = 33 - 37mph
Old Jun 25, 2007 | 04:32 PM
rockfish123
This was the first time the trans fluid and filter was ever changed. But is more of a super postive shift than a clunk. and its only when it shifts.
