more starter problems
Old Aug 27, 2017 | 06:13 AM
  #31
FuzzFace2's Avatar
FuzzFace2
Originally Posted by evil_motors
yes i will probably just grab a few wiring harnesses from a local store and wire it up. needs to be fixed before i do anymore troubleshooting. But yes there seems to be a short. something is giving the S wire voltage when the brake lights or turn signals are on. the harness i found is a 12 pin plug that was on the drivers side near the brake booster. it was one of many connectors over there. but it was the only one with broken/bare wires.
My thought is the left turn/brake wire was shorting out on 1 of the NSS wires sending power to the S lug on the solenoid.
If you did not want to hit the JY 2-6 pin connectors in the above like would work. https://www.etrailer.com/Wiring/Hopkins/37995.html
Also any you get from the JY may be just as bad that 6 pin looks like someone cares when doing the work on the truck.
2-6 pins is how I would roll, little solder and heat shrink and call it done.
My .02
Dave ----
ps: Etrailer is easy to work with as I have gotten parts from them.
pallanwilson
Jul 14, 2010 05:24 AM
gvrangr98
1983 - 2012 Ranger & B-Series
Mar 24, 2010 07:15 AM
MacAttack8401
Aug 30, 2009 05:49 PM
78workhorse
Electrical Systems/Wiring
Jul 18, 2008 03:45 PM
sjohnson18
May 5, 2004 11:41 AM
