starting problem
Old May 4, 2004 | 10:59 AM
sjohnson18's Avatar
sjohnson18
Angry starting problem
i have a 1990 ford ranger and it will not start... i have replaced the solenoid, battery, bench tested the starter and made sure the ground is intact...i have been working on this for days... i can't seem to get the starter to engage on the truck.. the solenoid only clicks...voltmeter across battery reads 13.0 volts both without the key on and when key is turned on... i have also hand cranked the crankshaft and checked all fusess.... please help..
Old May 4, 2004 | 12:22 PM
Ken00's Avatar
Ken00
Welcome to FTE!!!
I sounds like your down to a corroded cable, the get corroded inside and you can't see it.
Old May 4, 2004 | 02:45 PM
87 XLT's Avatar
87 XLT
Like Ken sez, it's probably a bad cable. Try adding a jumper cable til it starts.
Old May 5, 2004 | 09:13 AM
sjohnson18's Avatar
sjohnson18
Unhappy
thanks for the help...the cable from the solenoid to the starter was very corroded inside.. i really appreciate it
Old May 5, 2004 | 11:41 AM
87 XLT's Avatar
87 XLT
Thanks for the update, glad to hear it's fixed.
Wooticus
Jun 16, 2013 11:57 PM
drewduncan15
Aug 4, 2012 11:14 AM
84F-250HD460
Apr 29, 2010 10:25 AM
79 bronc
Electrical Systems/Wiring
Oct 21, 2007 09:11 AM
