1st time under valve covers, check my work
So thinking this thing out, it started the issues a couple weeks after I first pulled the PCM to get the codes off it to order the chip, and progressively got worse atter I pulled it again to put the chip in. Last night I thought about that cheap ground clip, and if it might not be making good contact. So this morning i pulled the PCM, ground clip was nice and stiff and seemed like it would make good contact, but I thought it was a crappy afterthought design. So I took a piece of black 18g wire, put a spade terminal on one end, and a small ring terminal on the other. I flattened the ring terminal, and put it on one of the long PCM case bolts at the rear near the chip opening, and ran the wire out with the TS6 cord, hooked the spade terminal to a female end grounded under the dash (so if some numbskull isn't paying attention the spade will seperate) and reinstalled.
Extra ground
Now I know I have a good ground to PCM housing. No trouble as of yet today. We'll see if that's all it was.
Extra ground
army_sapper68
02-07-2011 07:15 AM
fordguy_460
08-18-2009 04:28 PM
junkyard4
13
03-16-2009 08:10 PM
