What comes first?
Old Aug 17, 2017 | 09:03 PM
BrandonsE99psd's Avatar
BrandonsE99psd
What comes first?
I'm debating on my next purchase on my E99. But I'm not sure if there's an order to doing this? Can I get away with slightly larger injectors before i uprgrade the turbo? And if so will a wicked wheel help with a boost fooler? Or should the trans be built before doing any of the above? Not looking for anything more than 350hp. I'd say the truck sits around maybe 310hp as of now. Just trying to see what I can get away with, while staying in safe boundaries!
Old Aug 17, 2017 | 10:13 PM
Colorado350's Avatar
Colorado350
Hey Brandon,
Look at the pic, if your turbo is stock you already have the wicked wheel. Learn about your E99 before you spend your money.
Old Aug 17, 2017 | 11:39 PM
BrandonsE99psd
Palm to face*
Old Aug 18, 2017 | 05:55 AM
Walleye Hunter's Avatar
Walleye Hunter
Even though it has a WW would a new, billet wheel not help? If it's lighter it should spool up faster.
Old Aug 18, 2017 | 06:08 AM
BrandonsE99psd
So what are my limits with my turbo? Should I not be pushing more than 25psi?
Old Aug 18, 2017 | 07:09 AM
Tugly's Avatar
Tugly
What about your air intake? Our transmission is on the edge with stock power... so there's that. Bigger sticks need tuning... so add the price of a chip to the injectors.
I upgraded air in, through, and out; upgraded to a T500 to improve ICP, put in an HD4R100, and had my chip and gauges before I upped the injectors. A bent driveline and a spun bearing in the rear convinced me to later install traction bars - but I went with 160/100 injectors for 400 HP.
It's easy to overlook what gets whacked when you smack the ponies with the whip.
Old Aug 18, 2017 | 07:19 AM
BrandonsE99psd
im ordering an S&B soon and automeeter gauges. I have a hydra tuned by Full Force. But what is a T500? I'm thinking about doing 160/80 injectors. But I'm on the line here of doing trans first or injectors, I'm just wanted to play it safe and see what route everyone else has took.
Old Aug 18, 2017 | 09:03 AM
BBslider001's Avatar
BBslider001
Do. Your. Transmission. No question....then consider the injectors.
Old Aug 18, 2017 | 09:18 AM
andym's Avatar
andym
If you put 160/80 injectors in and upgrade the turbo, you will need a new transmission within a few weeks or months depending on your driving style. These transmissions can stand up to a stock engine very well for many hundreds of thousands of miles, but when you start adding extra power, things go downhill quick.
Old Aug 18, 2017 | 11:38 AM
BrandonsE99psd
So with my truck only being customed tuned with air intake and exhaust will it still be as reliable?
Old Aug 18, 2017 | 12:58 PM
andym's Avatar
andym
With an intake and exhaust? You'll be fine
Many of us run much more custom stuff than that and expect things to be reliable. Maintenance-free? Not so much. But reliable, yes.
Old Aug 19, 2017 | 11:39 AM
ExPACamper's Avatar
ExPACamper
I believe the e99 has the original wicked wheel, which spins up quickly and doesn't suffer from turbo stall. But the newer wheels (WW-2 and others) are supposed to flow a lot more air, whereas the WW1 runs out of air at the top.
That's been my experience so far, but I'm not an expert
ilike2fixit
Jan 6, 2025 11:45 AM
RacinJasonWV
38
Aug 7, 2017 03:11 PM
bcaughhorn
15
Jul 11, 2015 07:51 AM
ilike2fixit
Mar 4, 2015 08:12 PM
racer956
Feb 24, 2005 04:19 PM
