EBPV actuator
Old Aug 19, 2017 | 03:50 PM
Ethan Robinson's Avatar
Ethan Robinson
EBPV actuator
Alrighy guys need a little advice, long story but had my turbo an pedastal off, I found the butterfly in the turbine housing was stuck stuck, so i kinda got some ideas here and there, and here's what I did.
Removed butterfly and just bolted the hole with high temp sealant and 1/2" bolt. On the pedestal I took the guts out plugged the rod hole and cut the rod where the piston just barely let the aluminum cap set all the way. Then just plugged the wires back in an off we went.
My question is after doing more reading am I going to damage the turbo?
Old Aug 19, 2017 | 04:28 PM
hydro man 17's Avatar
hydro man 17
Deleting the EBFV is common and won't hurt anything as long as there are no restrictions. The main down side is if you live in a cold weather climate is extended warm up time.
Old Aug 19, 2017 | 06:41 PM
SaintITC's Avatar
SaintITC
I'm pretty sure this is wrong. Isn't the big piston supposed to be pushed in past both holes inside the bore? I thought that normal operation allowed low pressure engine oil to flood the bore, and when the valve is to be actuated the solenoid closes the drain, allowing pressure to build and push the piston deeper, opening the butterfly.
SkySkiJason
Jun 7, 2011 09:31 AM
plgebbia
Jul 13, 2010 10:15 PM
yellow401
Mar 1, 2006 11:10 PM
nhancock
24
Feb 8, 2005 07:42 PM
jesse460
22
Nov 28, 2004 07:34 PM
