NP205 Speedometer Gears
Old Aug 15, 2017 | 08:30 PM
1972RedNeck's Avatar
1972RedNeck
1974 F250 4X4. Originally had 4.10 gears in the rear and 7.50x16 tires. I just swapped to 3.31 gears (Dana 61 out of a late '70's F250 2wd) and need a new speedometer gear/gears. Still running 7.50x16 tires.
Can anybody point me in the right direction as to which driven (and drive) speedometer gear that I need?
Thanks
Old Aug 16, 2017 | 09:51 AM
Aaron-71's Avatar
Aaron-71
Thanks
The search function is your friend. Most of the information for our trucks is already posted on these forums through almost 2 decades of this forum's existence.
Post #25 in this thread (below).
https://www.ford-trucks.com/forums/1...edometers.html
Old Aug 16, 2017 | 01:58 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C6 or M/T?
With 3.31 ratio & 7.50-16 tires, the nylon DRIVEN gear has 17T that with its shaft pointing down, run this-away: ////
Old Aug 16, 2017 | 03:33 PM
maddogjohnson's Avatar
maddogjohnson
Since you're 4x4, presuming you have a divorced NP-205, you likely have 7 drive gear teeth according to this page http://offroaddesign.com/NP205Tech.htm. You can confirm by pulling the speedo gear out of the transfer case and counting the teeth.
Use the Ford Speedometer Calculator to determine # of teeth needed for your driven gear.
If you use 31.8" for tire diameter along with your 3.31 gears & 7 drive teeth, then you come up with a result of 15.19 driven gear needed teeth.
You'll have to verify whether or not 31.8" is accurate for your particular 7.50x16 tires.
Old Aug 16, 2017 | 03:50 PM
NumberDummy
Originally Posted by maddogjohnson
Since you're 4x4, presuming you have a divorced NP-205, you likely have 7 drive gear teeth according to this page Offroad Design - Tech.
DRIVE gear located on the output shaft, DRIVEN gear located at the end of the cable.
In post #3, I listed the correct Ford truck parts catalog DRIVEN gear for the OP's application, but did not list the DRIVE gear, because I need to know if the OP's truck has a M/T or C6.
With a C6, the DRIVE gear cannot be replaced, as it's made as part of the output shaft.
Old Aug 16, 2017 | 04:27 PM
maddogjohnson
My understanding is that the transmission M/T vs A/T doesn't matter if you have a 4x4 because the speedometer cable goes into the transfer case. I came across another post on the topic by OP that NumberDummy responded to where OP was seeking info on the drive gear in the t-case x-post link.
With that in mind. 7 tooth drive gear is what you need in your t-case according to Offroad Design - Tech. (very bottom of page). OP - Are you replacing the t-case drive gear because it is stripped? Best way to verify what you have now is by pulling the speedo cable & counting teeth in t-case to verify.
Old Aug 16, 2017 | 07:54 PM
1972RedNeck
It is a M/T, but as stated, that shouldn't make any difference as the Speedo Gears are in the NP205 Transfer Case.
1972RedNeck
Apr 20, 2016 03:21 PM
hivoltj
Mar 17, 2016 09:47 PM
Rusty_Old_F250
Jan 29, 2012 03:04 PM
Dodge/Cummins
Jun 9, 2008 10:29 PM
wick246
Mar 18, 2003 09:12 PM
