Speedometer gear help
Old Mar 16, 2016 | 02:51 PM
hivoltj's Avatar
hivoltj
'77 2wd F-150 with a C6. 4.10 rear gears and 29" tall rear tires. Currently has an 18 tooth speedo driven gear and the speedometer reads about 20% too fast.
I believe the c6 has a 7 tooth drive gear but I'm not sure. I'm thinking I need a 19 or 20 tooth driven gear to get it right but I'm not sure.
At one time I had found a really good speedo gear calculator but now I can't.
Help!
Old Mar 16, 2016 | 03:50 PM
scottscott's Avatar
scottscott
If your speedo is reading 20% fast with an 18 tooth gear, you need a gear with 20% more teeth to slow it down to be accurate. That comes out to a 21.6 tooth gear. Have to try a 21 & 22 & see what gets you closest.
21 tooth are out there, 22 & 23 seem to be harder to find.
Here's a source for a set of gears, more than you need, but it includes a 21. I have personally used the gears this vendor sells with no issues, very happy with them. http://www.ebay.com/itm/Ford-SPEEDOMETER-GEARS-7-PIECE-KIT-with-GEAR-CLIP-NOS-Mustang-T-Bird-/141921174527?vxp=mtr
Old Mar 16, 2016 | 06:31 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Here's a source for a set of gears, more than you need, but it includes a 21. I have personally used the gears this vendor sells with no issues, very happy with them. Ford Speedometer Gears 7 Piece Kit with Gear Clip Mustang T Bird | eBay
Ford supplies 16 thru 21 tooth nylon DRIVEN gears, no such thing as a 22 or more toothed gear.
These gears have been available from Ford since 1960, also available from auto parts stores.
Old Mar 16, 2016 | 07:59 PM
hivoltj's Avatar
hivoltj
I think 22 and up are available aftermarket but because of the pitch they get ate up in 30,000 miles or so
Old Mar 17, 2016 | 04:57 PM
scottscott's Avatar
scottscott
Yes, aftermarket has 22 & 23 tooth driven gears.
So, there is such a thing, just not a genuine Ford part. 23 Tooth Ford Speedometer Driven Gear | eBay
Not a big deal, just wanted to let folks know they are out there. Sometimes a gear like this is the easiest & cheapest way to get on the road.
Old Mar 17, 2016 | 09:47 PM
blue04.5's Avatar
blue04.5
Late model restoration has a speedo gear calculator. Hope it helps. They also have gears up to 23 tooth, maybe more I dont remember at the moment.
hivoltj
17
Dec 25, 2018 09:53 PM
1972RedNeck
Apr 9, 2012 01:33 PM
66crawler
20
Aug 17, 2010 01:22 PM
F250driver
Sep 14, 2008 07:21 PM
Violjohn78
Jul 23, 2005 05:36 PM
