79' Ford Cab rust
Old Aug 16, 2017 | 03:30 PM
PL Allcritnohit's Avatar
PL Allcritnohit
79' Ford Cab rust
I have rust above the door seal just below the roof how hard would it be to fix this ? How much would it cost for a pro to do it ?
I also have rust below the door seal would this be an easy/cheap fix?
Old Aug 16, 2017 | 04:32 PM
72rtchallenger's Avatar
72rtchallenger
Depends on your welding skills, they sell some weld in parts like the lower rocker but unsure how they fit or size,,but if you cut some areas and weld in plates you can make it look good if your any good at welding and hammer an dolly you can make the pieces since your looking at small areas . Of course til you cut out the bad you don't know how much more needs replaced
Old Aug 16, 2017 | 08:47 PM
PA74F250's Avatar
PA74F250
Better of getting another cab, it'll forever haunt you.
Old Aug 17, 2017 | 12:19 AM
78_f800crewcab4x4's Avatar
78_f800crewcab4x4
I see that fiberglass windshield visor has caused the rust out condition. How many holes were drilled into the roof? That's the problem.
That bottom A-pillar rust is an easy fix. A few hours per side.
The roof skin needs to be replaced. About a week worth of work.
Old Aug 17, 2017 | 12:23 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
X2 on most of that is because the Lund cab visor that you can see in the 1st pic. Cut out the rust and weld in patch panels.
powerstroker100
May 1, 2015 06:01 PM
fabieber
Feb 25, 2014 08:04 AM
JustBlaze
Apr 23, 2011 12:22 PM
emeraldcoupe
13
Sep 1, 2010 09:26 PM
