Regen frequency
Old Aug 11, 2017 | 10:09 AM
U235Fishin''s Avatar
U235Fishin'
It's all about exhaust temperature
When I am driving unloaded the engine isn't working as hard and exhaust temperatures are lower. In this case the regen interval is 150-200ish miles. When I am towing EGT-4 is usually 700-900F and I usually run into the so called manditory 500 mile regen. '12 CCSB with diesel kleen.
Old Aug 11, 2017 | 10:13 AM
scraprat's Avatar
scraprat
Top Answer: 5
Originally Posted by camminich
My 16 goes about every other tank per regen (400 to 500 miles). And to 2nd what Skimuggs said, avoid the short trips. I think idle time may affect that too. I usually only warm my truck for 3 to 5 mins when cold and rarely just let it idle.
Ah, I so wish I could find someone to do this. So far 2 dealers that I have contacted have just stared at me blankly like I was asking them to mount wings to the headlights. One asked that I leave it with them for a few days, and they would figure it out, but also said come back in 3 weeks to do that.
Show them this thread or write it down and give it them. https://www.ford-trucks.com/forums/1...l#post15868051
post #27
Old Aug 11, 2017 | 10:25 AM
camminich's Avatar
camminich
I love some dealers (extreme sarcasm) I mentioned to one about the posting and I get the "oh you forums guys" response. Like I'm pulling it out of my ****...
I think I just need to poke around and find someplace not local to my area to have this done. So far too, my shops you deal with just the service advisor, and not actually with the techs, neither would let me connect directly.
Old Aug 11, 2017 | 10:48 AM
jav_eee's Avatar
jav_eee
You could poke around on forscan and have it done in your driveway in less than 15 minutes. And that's if it's your first time on forscan. Even threw in some time to take a few sips of beer in my estimation.
Old Aug 11, 2017 | 04:30 PM
SkiSmuggs's Avatar
SkiSmuggs
This is how to get to the %DPF screen for "Exhaust filter".
(1) IDS "talking" with truck via VCM
(2) Toolbox selected to get to the Module Programming
(3) Programmable Parameters for our trucks
(4) Select Personality Parameter to program
(5) Change "Forced Regeneration Request" to Enabled.
(6) Programming complete and VCM can be disconnected from truck
Ghost Screen now appears
__________________
Old Aug 11, 2017 | 04:31 PM
Jeff Campbell's Avatar
Jeff Campbell
I went through the same aggravation. Drove me nuts! After contacting or visiting 6 dealerships, I finally found one that did it. Was actually recommended to me on this forum. Difference was, very small town dealership that allowed me to speak directly to the diesel tech. Took him 10 minutes.
I highly recommend getting it done somehow. I love having it activated.
Old Aug 11, 2017 | 05:01 PM
scraprat's Avatar
scraprat
Top Answer: 5
What's nice about having the screen is knowing roughly when your going to get a regen with a simple touch of a button.
Old Aug 12, 2017 | 01:46 PM
ssunit1's Avatar
ssunit1
To give credit where credit is due the info below is from Scraprat's post on 1/27/16 here on FTE.
I printed it off, gave it to the service tech and 10mins or so later it was on my ghost screen. BTW the tech had not heard of this either until I told him and give the printout.
Sorry for the copy and past job but I don't know how to do the link so it just shows what Scraprat posted.
Hope this helps.
________________________________
I just purchased my truck and explained the ghost screen to the sales guy he said just send the instructions. When I picked up the truck the screen was there, no problem and I'm sure there where other trucks getting it now that they know how to do it.
This is what I sent,
This is how to get to the ghost screen for "Exhaust filter".
Old Aug 12, 2017 | 04:02 PM
scraprat's Avatar
scraprat
Top Answer: 5
Thanks for the credit but I was just relaying what I learned from our FTE brothers. If I could remember who I learned it from I would pass the credit to them.
Old Aug 12, 2017 | 06:08 PM
Geno C's Avatar
Geno C
My 13 dually has been regenning at 500 miles +\- 15 from when I bought it at 50,000 till just this summer at 81,000. Now I'm getting 3-400 miles. Nothing has changed with my driving habits at all. Fuel from all the same stations as last years. Might be time for a delete before it starts causing problems.
Old Aug 12, 2017 | 08:56 PM
ssunit1's Avatar
ssunit1
Hope this helps.
Sorry SkiSmuggs, I don't know how I missed your post of the exact same thing just a little up the page.
Old Aug 13, 2017 | 10:39 AM
Chuck-B's Avatar
Chuck-B
6.7 Weight Loss
Would this be the same with the Forscan app? If not does someone have how to turn it on with the Forscan app?
Old Aug 13, 2017 | 11:21 AM
  #28
GregWork's Avatar
GregWork
Download the Forscan app, get an OBD2 connector and change as below:
IPC 720-01-01 **** 9*** **** DPF % Screen Enabled
IPC 720-01-01 **** 1*** **** DPF % Screen Disabled
IPC 720-01-01 **** **** E*** Force Regen Request (Disabled)
IPC 720-01-01 **** **** F*** Force Regen Request (Enabled)
IPC 720-01-01 **** **** 6*** Force Regen Request (Disabled) / Compass (Enable)
IPC 720-01-01 **** **** 7*** Force Regen Request / Compass (Enabled)
Change the "1" to a "9" and the "E" (basic screen or "6" on productivity) to an "F" (or a "7" on productivity) on the IPC as built screen. (save your factory as built config file first in case you need to reload it)
Old Aug 13, 2017 | 11:27 AM
  #29
jav_eee's Avatar
jav_eee
The forced regen doesn't work on all models, does it?
Old Aug 13, 2017 | 12:40 PM
  #30
GregWork's Avatar
GregWork
I think it only works when you have 100% full on gauge and are parked.
