passenger door hinge- issue
Old Aug 10, 2017 | 03:31 PM
Aquarium7's Avatar
Aquarium7
HI first time post, I looked around, but did not find the answer.
i have a 2011 E250 van. The wind caught the passenger front door and blew it back and over extended the hinges. the door closed but rubs, so not using the door is the best option.
I bought new hinges and deciding if this is worth tackling or passing it to a garage to handle. Looks simple at first but look possibly complicated to access.
Is replacing the upper and lower hinges really complicated and difficult to access? or just have to remove plastic pieces?
Thank you
Old Aug 10, 2017 | 05:39 PM
98Econoline150's Avatar
98Econoline150
It is not so bad to replace hinges. Make sure the cowl isn't damaged. I replaced a hinge on the driver side of mine. I took the fender off to make it easier to get at the bolts, but there may be a better method.
Old Aug 11, 2017 | 04:21 PM
vettex2's Avatar
vettex2
careful not to drop the bolts down into the body
Old Aug 11, 2017 | 09:04 PM
annaleigh's Avatar
annaleigh
If you have never had a door off, they are a good bit heaver then one might think.. A helper and good support under the door is a excellent idea..
Old Aug 12, 2017 | 04:52 PM
jimbomitch's Avatar
jimbomitch
I doubt if new hinges will cure your problem. It's probably the post where they mount. I've had success in the past by placing block of wood in the jamb and pushed on the door as if you're closing it. I will caution you that this takes some "feel" and could make things worse.
98Econoline150
Jun 1, 2015 10:09 PM
evil_motors
Oct 25, 2012 09:40 PM
1994diesel
Mar 24, 2008 11:35 PM
BGL
1978 - 1996 Big Bronco
May 31, 2005 09:44 PM
boulderdentist
Paint & Bodywork
Jan 19, 2004 08:05 PM
